Need to move OS from wrong partition to correct partition
I accidentally installed Kubuntu to the end of one of my HD’s, sda6 3.8Gb and want to move it to sda5 110Gb but after cloning an image of sda6 with Clonezilla and trying to write it to sda5. I find that I am only given sda1 to write to. Why is that?
No idea … but why not just delete sda5 … move sda6 into the space now vacated, and expand ?
WARNING … Backup anything you cannot afford to loose first.
Didn’t work so I wiped the HD and reformatted and now going to reinstall the OS’es I put on there (They were clean installs so no loss).
But for some reason, I am having trouble with the GFX drivers as the screen is all black after I have installed Ubuntu 12.04 and in Kubuntu 14.04 the pop up selection boxes are all shrunk and stretched!
what graphics card / drivers:
sudo lshw -C display
pooky2483@pooky2483-Kubuntu-1204-3:~$ sudo lshw -C display
[sudo] password for pooky2483:
*-display
product: NV44 [GeForce 6200 TurboCache]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:18 memory:fa000000-faffffff memory:d0000000-dfffffff memory:f9000000-f9ffffff memory:fbee0000-fbefffff
I managed to install Ubuntu14.04 and there is no problem with the display (after installing updates and selecting the correct driver), just on install.
So you still having a problem or not ?
If you’re still getting a black screen booting 12.04 … try temorarily adding “nomodeset” as a kernel boot parameter (to get you booted), then install the correct drivers.
