New Installation of Peppermint 9 on dual boot system(Solved)
Hi All,
I have an old but very reliable Dell Inspiron 1640 that is currently running Ubuntu 14.04 dual booted with peppermint 6, I have downloaded and burned to disc Peppermint 9 and have run this from the live disc with no problem (64 bit), I would like to replace initially the Ubuntu 14.04 with the peppermint 9 and when happy this is running well remove the pepermint 6 also.
degsy@degsy-MM061 ~ $ sudo fdisk -l
[sudo] password for degsy:
Disk /dev/sda: 120.0 GB, 120034123776 bytes
255 heads, 63 sectors/track, 14593 cylinders, total 234441648 sectors
Disk identifier: 0x0001c80a
/dev/sda1 * 2048 172790376 86394164+ 83 Linux
/dev/sda2 172791806 234440703 30824449 5 Extended
/dev/sda5 231317504 234440703 1561600 82 Linux swap / Solaris
/dev/sda6 172791808 225026047 26117120 83 Linux
/dev/sda7 225028096 231315455 3143680 82 Linux swap / Solaris
Partition table entries are not in disk order
Your advice on what is the best way to achieve this would really be appreciated.
Thanks in advance,
Degsy
Boot into Peppermint 6, and post the contents of
gedit /etc/fstab
make 100% sure you post this output from Peppermint 6 … NOT Ubuntu.
as requested output from peppermint 6
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda6 during installation
UUID=b5cba5e4-ca3b-4bc2-81c2-cf10fab29851 / ext4 errors=remount-ro 0 1
swap was on /dev/sda5 during installation
UUID=b73c8a18-387e-4f10-a296-4c9363cd4d7c none swap sw 0 0
Regards,
Degsy
Sorry, I forgot to ask for the output from:
sudo blkid
As requested:
degsy@degsy-MM061 ~ $ sudo blkid
/dev/sda1: UUID=“7b933a4f-ce32-4726-b52d-427d2d154956” TYPE=“ext4”
/dev/sda5: UUID=“b73c8a18-387e-4f10-a296-4c9363cd4d7c” TYPE=“swap”
/dev/sda6: UUID=“b5cba5e4-ca3b-4bc2-81c2-cf10fab29851” TYPE=“ext4”
/dev/sda7: UUID=“dfa63e69-af4f-47ae-883d-8d090067bf29” TYPE=“swap”
Regards,
Degsy
Have you got an Ubuntu 14.04 or Peppermint 6 LiveDVD/LiveUSB ?
Because the first thing we need to do it make sure GRUB stage one is pointing at grub stage two on Peppermint 6 … so when we remove Ubuntu, Peppermint 6 is still bootable.
I just want to make sure you’re equipped in case this goes wrong.
Have checked and I do have live DVD for both but would trust the Pepppermint 6 ahead of the Ubuntu, I think for some reason they are 32 bit versions, would that matter?
In the worst case scenario, I will ensure that any files I want are fully backed up on an external drive so that if necessary we could always just install Peppermint 9 as a single boot system.
Regards and thanks for your help do far,
Degsy
Is the installed Peppermint 6 32bit or 64bit ?
I have just checked this and the installed peppermint 6 is 32 bit.
Degsy
Okay then
Boot to the Peppermint 6 LiveUSB
Open a terminal and run these commands in sequence
sudo mount /dev/sda6 /mnt
for i in /dev /dev/pts /proc /sys /run; do sudo mount -B $i /mnt$i; done
sudo chroot /mnt
grub-install /dev/sda
update-grub
then hit Ctrl+D (to exit the chroot environment).
Shut down the PC
Remove the LiveUSB
Boot up the PC (without manually choosing an OS at the GRUB screen)
Did it automatically boot into Peppermint 6 ?
Thanks for your help, carried out the instructions you gave, yes on booting the laptop went automatically into Peppermint 6 without me selecting anything from the Grub screen.
Regards,
Degsy.
Okay, boot into the Peppermint 9 LiveUSB/LiveDVD and select “Try Peppermint”
Once at the desktop fire up GParted, and delete these 2 partitions
/dev/sda1
/dev/sda7
then apply the changes.
Now do a regular install (from the Install Peppermint icon on the desktop), and it should offer to install Peppermint 9 ALONGSIDE Peppermint 6
(if it doesn’t offer this, back out of the installer and let me know)
Just to let you know all went well and Peppermint 9 is now installed alongside Peppermint 6 on this trusty old Dell Inspiron.
I will mark the topic as solved, but will no doubt be back with further questions in the near future, in the meantime looking forward to enjoying Peppermint 9 as much as I have Peppermint 6, which has been a trusty servant over the last 4 years or so.
Many, many thanks for your very kind help again,
Regards,
Degsy
You’re most welcome Degsy :slight_smile:
