New sound card white noise only
Let’s be clear about this … have you BOOTED to the Ubuntu LiveCD, selected “Try Ubuntu”, and checked if sound works in the “Live” environment ?
How exactly are you testing the audio ?
What happens if you run this command:
aplay /usr/share/sounds/alsa/Front_Center.wav
Do you hear anything ?
I didn’t hear anything from that command what I usually do is play a web based video from the BBC, I just played a movie but no sound from any
Are you planning on answering my question about whether sound works from a LiveCD ?
Testing with web based audio isn’t a good idea … that could be caused by the flashplayer, codecs, etc.
(same goes for a DVD)
to test audio after any changes, ALWAYS use that command:
If it works … you will hear a womans voice say “front centre
That command doesn’t require ANY extra plugins/codecs/players/etc. … thereby ruling those out as the cause of the problem.
I run the command front centre but no sound
If you’re not going to answer my question … I can’t help you … I’ve asked 4 times now whether sound works when you boot to a LiveCD, and still not received a clear and concise answer. :o
sorry I missed the top half of 22 but I’m a bit cofused as to what you mean, but I do have a driver installation disk it has linux files on
Have you got an Ubuntu 12.04 LiveCD ? ← the CD you probably used to install Ubuntu 12.04
If so, boot to it, select “Try Ubuntu”, and when you get to the desktop, open a terminal with Ctrl+Alt+T … and run:
Do you hear sound.
I’m trying to eliminate your hard drive installation, and find out if sound works WHILST RUNNING FROM THE LIVECD
This will tell me if it’s a general problem … or a problem that’s specific to YOUR installation.
DO NOT just run the above command … it MUST be whilst booted to a LiveCD
I’m not sure it’s what you meant but I got to a sound test feature as I clicked each button I got a woman saying front left, front right
WAS THAT WHILST BOOTED TO A LIVECD ? … or from the hard drive ?
Is there any particular reason you’re ignoring half the questions I ask you ?
I can’t use keyboard short cuts but it was on try booted from 12.04 it say’s I have no tray for exiting would this have an effect on it
I’m having SERIOUS trouble following what you’re saying.
DID YOU BOOT TO A 12.04 LIVECD and run the sound test ?
Yes I select shutdown and restart and let it boot to the try 12.04 went to audio clicking each button and get a woman saying front left, front right
But if you click the same buttons whilst booted to the hard drive you get no sound ?
I can’t get to it if I try applications directly it takes me to a different part of the sound app or if I try to get to it via the DVD it takes me to the magazine and articles I also tried cut N paste your command from the hard drive but no sound It dosen’t see the memory stick from the DVD
Things to try …
Plugging the speakers into a different jack plug hole on the sound card.
Install gnome-alsamixer:
sudo  apt-get install gnome-alsamixer
and pavucontrol:
sudo apt-get install pavucontrol
Check there’s nothing muted in Gnome Sound Mixer (gnome-alsamixer)
Check in PulseAudio Volume Control … that
The “Ouput Devices” tab says it’s using your C-Media card.
The “Configuration” tab says Analogue Stero Duplex
Test sound between each change with the:
command.
there colour coded but would that make a difference with me getting sound on one side, there were I checked green to green pink to pink
Pink is the microphone … how many mini-jack plug holes are there.
What I’m hoping for it that it’s a 5.1 soundcard, so has jacks for front and rear speakers … maybe the back speaker socket is active, or vice versa.
it has 4 jacks, the manual describes It has a 4 channel PCI sound card with AC97 3D Audio Effects
So try the other jack plug sockets … you can’t do any physical damage.
And try the suggestions above.
I tried all the jacks both via DVD and harddrive no sound but I can check via the GUI not muted, but if I use your command I get this
[sudo] password for gordon:
Reading package lists… Done
Building dependency tree
E: Unable to locate package pavucontroll
gordon@gordon-desktop:~$
