New to Linux - Please Help
Hello everyone. OK so this is what brings me here:
I’m currently pursuing a CCNA certification. I need to use a so called “Eagle Server” to do my lab exercises. I have the Linux Live CD (FEDORA CORE 3 KERNEL 2.6.12) and I have installed it on a laptop that I have (TOSHIBA EQUIUM M50-164, PSM57E). This laptop had Windows XP installed, so I created a 4GB FAT partition and booted with the Live CD. I chose the option installonFAT, then after rebooting (with CD in the tray) I chose runondisk.
http://img508.imageshack.us/img508/9025/eagleserver.jpg
Ok, here is my 1st problem: I need the CD in the tray every time I want to run Linux. Without the CD, it boots to Windows XP. Also, according to Eagle Server documentation, any modification to the server is available even after reboot. Well, that is not happening to me. Does someone have a clue why the server doesn’t save the modifications? Is it because I need the Live CD to boot, even after I have installed on a FAT partition?
Another problem I have:
I need to connect the Eagle Server to a router using the Fast Ethernet LAN port:
http://img812.imageshack.us/img812/7187/eagleserver2.jpg
Eagle server supports only 1 network interface card, eth0. When I first run the server it showed me that the hardware mapped to eth0 was my wireless adapter. There is no option to disable it in my BIOS, so I just removed the hardware myself. After rebooting it show eth1394 on eth0. I presume that is the FireWire Adapter.
What can I do so that eth0 is mapped to my LAN adapter (Marvell Yukon 88E8036 PCI-E Fast Ethernet)?
Is there a way do disable FireWire?
Please remember that due to 1st problem above, any changes to the server are not available after reboot :frowning:
So the main problem is that I can’t ping from Eagle Server to the router and vice-versa :frowning:
If I could get any help on this, I would be greatly appreciated. Please note I’m a beginner in using Linux.
Thank you for your time.
First problem… I’d say the GRUB bootloader didn’t get installed.
is there anything in the 4GB partition you created ?
the instructions here explain how to fix GRUB
Eagle Server Installation Guide
Unless you understand how to reinstall GRUB or the Windows bootloader, can I suggest you either install it to a Virtualbox VM, or download the VMware image and player and run it in that.
As for the network interface goes…
ifup eth0
ifconfig
to check it has got an IP address from your routers DHCP server.
There may be a config file somewhere for the server itself, telling it which interface to use… but I can’t test this as I don’t have the software.
To be more specific, I’d have to test it myself… is there anywhere it can be downloaded from?
