Nice [PHP/HTML] system monitor
[smg id=1524]
A few questions (if you would be so kind) before I run off and install it on my VPS …
a) What is PHP’s “safe-mode”, as the README makes a big deal about disabling it ?
b) How is it accessed once installed ? … which isn’t in the README.
c) Is there anything in the config.php that could be a security risk ? … (from a cursory look) should I hide any of the network interfaces, VPN tunnels for example ?
d) is there any point in the “sensors” stuff on a VM/VPS ?
