No system tray detected on this system
Hi Guys got an issue with no system tray detected on this system unable to start exiting.
This began occuring after an update. on Ubuntu 12.04 Any ideas guys.
Cheers Makin
What happens if you run:
hp-systray
If it starts then take a look at this solution
Yup as SeZo suggests (if this only occurs at bootup, and the hplip system tray applet start if run from the commandline) it’s a timing thing … where hp-systray is attempting to start before the system tray is started.
