ogg/vorbis (mp3 like) player
can anyone recommend a mp3 player thats ok with ogg/vorbis format please
I take it you mean hardware ? … and not a software media player ?
yes hardware i know apple wont be any use but there must be one out there somewhere
How about the SanDisk Sansa Clip+ (4 or 8GB models with expandable SD card slot):
http://www.amazon.co.uk/dp/B0043M5UQ0/?tag=hydra0b-21&hvadid=9550951389&ref=asc_df_B0043M5UQ0
thanks mark ;D
If you’re gonna get one … be sure to read the second review at the link I gave :wink:
Apparently if you select “Europe” at the initial setup screen, it limits the volume … some crazy EU regs … so choose “North America” which doubles the available volume.
You can always change it, by resetting the device.
Other than that, it seems to have good reviews :slight_smile:
