Opening tabs for devices
Is there a limit as to how many tabs I can have open re opening them for devices as mine keep ‘crashing’ after opening 7 in 1 window.
tabs for devices ??
tabs in what ?
If you mean in the nautilus file manager … there was an issue with nautilus crashing in 11.10 which I assumed was fixed but could be wrong.
The fix was to (if present) delete ~/.nautilus with:
rm -rf ~/.nautilus
and completely uninstall the nautilus-open-terminal plugin with:
sudo apt-get remove --purge nautilus-open-terminal
If you absolutely MUST have the “Open Terminal Here” option … there is supposed to be a workaround using a script rather than the nautilus plugin here:
Don’t ask me how well this works though :slight_smile:
Another known issue that only seemed to apply to the Gnome (Classic) desktop in 11.10 was that nautilus sometimes crashed because of the Ubuntu One client … so if you don’t use Ubuntu One, you can uninstall the client with:
sudo apt-get remove ubuntuone-client-gnome
Sorry, I meant these tabs;
http://img822.imageshack.us/img822/4983/tabsd.th.jpg
I’ll uninstall Ubuntu One as I don’t use it, ta.
