Orgniser program for Ubuntu Gome
Hi all.
Can anyone recommend a calender organizer program that I can add alarms and reminders to. Ideally I would also like to link it to my phone (samsung galaxy Ace).
Thanks
Mark
This any good to you ?
Thanks but I am probably more old fashioned than him. I don’t want Google any where near my calender or the data within it. I would rather do without sync-ing them together.
I don’t like the way Google collects info about every thing you and I do on the net and on my phone. I have most of the info collecting things turned off, or all that I can find. The dam thing even tracked where I go and how I used the phone when it is turned on or it did untill I found out how to turn that part off. >:( >:( Sorry rant over.
I will keep looking for now and do with out it on the phone (sticking to paper diary).
There are plenty of calendars/organisers for Ubuntu … but I’ve never tried getting any of them to work with Android.
May have sommat to do with not having an Android phone (or any other smartphone) :wink:
So if we forget the phone bit, what is a good one to try?
I cannot advise on a calendaring application (do not use it and also have no smartphone) but here is a round up of some of them:
http://www.mmuer.info/calendars.html
Well if you use thunderbird, why not just give the “lightning” plugin a go:
or there’s a light (but very simple “reminder” application tkreminder
sudo apt-get install tkreminder
Or revert to Evolution instead of Thunderbird … which has a calendar built in that works with the Gnome shell.
Someone called Erick Pérez (one of the Gnome devs) is working on a “Gnome Calendar” … which isn’t supposed to be too far off … see here:
http://www.muktware.com/3829/gnome-calendar-getting-ready-prime-time
I suppose there’s nothing stopping you trying Korganizer (in the software repos) but expect it to drag in a LOT of KDE libraries too.
Thanks all. I will be having a look at them.
Ta
Mark
No problem … let us know if any of them fit the bill.
Hi. Finally got round to trying the tkreminder and got this in the terminal. What went wrong?
mark@mark-Aspire-5755G:~$ sudo apt-get install tkreminder
[sudo] password for mark:
Reading package lists… Done
Building dependency tree
E: Unable to locate package tkreminder
My apologies … it’s called tkremind, not tkreminder … try:
sudo atp-get install tkremind
Hi. Tried that and got
mark@mark-Aspire-5755G:~$ sudo atp-get install tkremind
sudo: atp-get: command not found
Mark
Hi SeZo.
I cannot get the link to work or find mmure.info Could you post it again?
Thanks
Mark
There’s no point in SeZo posting the link again … the link worked fine, it must be their web server is down or they’ve got rid of the page.
If you go here:
https://www.google.com/search?source=ig&hl=en&rlz=1G1GGLQ_ENUK368&q=www.mmuer.info%2Fcalendars.html&btnG=Google+Search
you,ll see the link at the top … but it’s broken
