Peppermint 3 stuck update
HI Mark,
I am struggling to post a message and could only do it sending this to you
I have an Acer Aspire One and happily updated to Peppermint 3 OS 6 months ago.
I have been installing updates regularly since then.
Yesterday I encountered a problem:
E: dpkg was interrupted, you must manually run ‘sudo dpkg --configure -a’ to correct the problem.
E: _cache->open() failed, please report.
I am out of my depth.
Would someone please tell me what to do.
Thank you.
Kevin
Hi woodward
Open the terminal (Ctrl-Alt-T) copy and paste the following command
you’ll be asked for your password, enter your password
hopefully that will fix the problem, if not let us know
Good luck
After that, I’d run
sudo apt-get update && sudo apt-get dist-upgrade
just to pick up any outstanding updates that have been missed
