Peppermint 4
Have installed and updated onto a spare HDD.
Is there a restricted -extras package for this O/S…?.
Jocklad
Yes … you need to make sure the “Independent” and “Canonical Partner” repos are enabled.
Menu > Preferences > Software & Updates > Other Software (tab)
then close that dialog
then update the package cache
Then install ttf-mscorefonts-installer
sudo apt-get install ttf-mscorefonts-installer
(hint … Use the Tab key to select OK and YES)
then install both ubuntu-restricted-extras and lubuntu-restricted-extras
sudo apt-get install ubuntu-restricted-extras lubuntu-restricted-extras
Or check out stages 4, 5, and 7 in this tutorial
http://linuxforums.org.uk/index.php?topic=11109.0
Got it Many Thanks.
A new O/S up and running in a couple of hours.
Jocklad ;D ;D ;D ;D ;D
I hope you enjoy Peppermint :slight_smile:
Now that you’ve installed the “extras” packages … if you’re likely to play any commercial DVD’s, you might also want to run:
sudo /usr/share/doc/libdvdread4/install-css.sh
to enable playback of DVD’s that use the CSS content scrambling system.
Thanks again Mark.
Have installed it.
Will give Peppermint a good run today. ;D
Jocklad
Delighted with Peppermint 4.
Its certainly given this old Dell a new lease of life.
Jocklad. ;D ;D ;D ;D ;D
Pleased to hear that … always nice to hear it’s saved another PC from the bin, and made it enjoyable again.
(not that I’m biased or anything ;))
Thanks for the feedback :slight_smile:
Have had no problems at all since Peppermint 4 installation.
How long is Peppermint 4 supported for…?.
Jocklad
Until Peppermint 5 is released next may/june(ish) … can’t be more precise than that as there’s no fixed release date, iit’s released when considered “ready” :slight_smile:
Peppermint is released annually, so is based on every “other” Ubuntu/Lubuntu release.
Peppermint 5 will “officially” be supported until Peppermint 6 a year later, but as it’ll be based on the Ubuntu/Lubuntu 14.04 Long Term Support release it will continue to receive at least security and bugfixes for the full 5 years.
Think of it like this … the Peppermint specific repository will stop receiving updates when a new version of Peppermint is released, but as 99% of it comes from the Ubuntu repos, you’ll get updates for 99% of it in line with the Ubuntu/Lubuntu release it’s based on.
And the 1% from the Peppermint specific repo tends to be mainly just configs, artwork, etc. … OK, and the Ice application, but nothing that should stop working or is a security risk if it’s not updated :slight_smile:
As Lubuntu are going fully LTS with 14.04, there’s a good chance Peppermint will too … I don’t think it will be too much work (if any) to support the Peppermint specific repo for the full 5 years, not much in there tends to need changes anyway.
Great Mark.
Thanks for your prompt reply.
Jocklad ;D
No problem :slight_smile:
Quote:Yes … you need to make sure the “Independent” and “Canonical Partner” repos are enabled.
Does that include ticking the source tabs for Independent" and "Canonical Partner…???
Jocklad
No, you can leave the (Source) items unticked … or tick them if you wish :slight_smile:
The full answer is - the (Source) repos are not “necessary”, but nor will they hurt anything … so your call.
Thanks Mark :slight_smile:
Jocklad
You’re welcome :slight_smile:
Is there the restricted extras for Mint 16 too?
I’m guessing it would be the ubuntu-restricted-extras package (if any) … though if I remember correctly Mint has support for the stuff the “extras” package adds by default.
If you can play flash, mp3’s,and commercial DVD’s by default you don’t need the “extras” :wink:
ubuntu-restricted-extras is just a metapackage that pulls in some other packages as dependencies/recommends … here’s a list of the packages ubuntu-restricted-extras installs:-
ubuntu-restricted-addons
unrar
gstreamer0.10-plugins-bad-multiverse
libavcodec-extra-53
ubunbtu-restricted-addons then pulls in:-
gstreamer0.10-plugins-ugly
gstreamer1.0-plugins-ugly
adobe-flashplugin | flashplugin-installer (either ONE of those, NOT both)
gstreamer1.0-plugins-bad
gstreamer0.10-ffmpeg
gstreamer1.0-libav
gstreamer0.10-fluendo-mp3
So if you already have the ones in bold, you’re not going to need the ubuntu-restricted-extras package.
Be aware the above info is for Ubuntu 13.04 … the package versions might be slightly different in Mint 16 which is based on Ubuntu 13.10
Muchas Gracias!
see the edit above.
