Peppermint 8 stuck when shutting down (resolved)
After trying out a live usb for a few days I installed Peppermint 8 64bit on my laptop.
All went well I like the look of the system problem happens when sellect shutdown or reboot.
All starts well the progres bar is moving then it stops about 1/3 of the way and just gets stuck after 10 mins I just have to switch it off.
If you hit the “Esc” key when the shutdown appears to hang, is there any text displayed on screen ?
The keyboard is frozen and so hitting Esc has no effect.
Can you post the output from:
inxi -Fz
mount
usertwo@usertwo-R59P-R60P-R61P ~ $ inxi -Fz
System:    Host: usertwo-R59P-R60P-R61P Kernel: 4.10.0-37-generic x86_64 (64 bit)
           Desktop: N/A Distro: Peppermint Eight
Machine:   System: SAMSUNG product: R59P/R60P/R61P v: 03YI
           Mobo: SAMSUNG model: R59P/R60P/R61P
           Bios: Phoenix v: 03YI date: 10/01/2007
CPU:       Dual core Intel Pentium Dual T2310 (-MCP-) cache: 1024 KB
           clock speeds: max: 1467 MHz 1: 1467 MHz 2: 1067 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS600M [Radeon Xpress 1250]
           Display Server: X.Org 1.19.3 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: [email protected]
           GLX Renderer: Gallium 0.4 on ATI RS600 GLX Version: 2.1 Mesa 17.0.2
Audio:     Card Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.10.0-37-generic
Network:   Card-1: Qualcomm Atheros AR242x / AR542x Wireless Network Adapter (PCI-Express)
           driver: ath5k
           IF: wlp2s0 state: down mac: <filter>
           Card-2: Marvell 88E8039 PCI-E Fast Ethernet Controller driver: sky2
           IF: enp5s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 160.0GB (6.3% used)
           ID-1: /dev/sda model: WDC_WD1600BEVS size: 160.0GB
Partition: ID-1: / size: 144G used: 6.9G (5%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.95GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID:      No RAID devices: /proc/mdstat, md_mod kernel module present
Sensors:   System Temperatures: cpu: 57.0C mobo: 57.0C
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 173 Uptime: 19 min Memory: 947.8/2753.0MB
           Client: Shell (bash) inxi: 2.2.35
usertwo@usertwo-R59P-R60P-R61P ~ $ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1385544k,nr_inodes=346386,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=281908k,mode=755)
/dev/sda1 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=22,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12955)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=281908k,mode=700,uid=1000,gid=1000)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
Try running these 3 commands prior to shutting down
sudo swapoff -a
sudo ifconfig wlp2s0 down
nmcli networking off
now does it shut down properly ?
If it does that narrows things down, if it doesn’t we’ll try something else.
If shutting down still hangs, when it’s hung does hitting Ctrl+Alt+F3 leave you at a text console with a login prompt ?
and have you still got the LiveUSB ?
I ran sudo atp-get update this found some downloads that I installed and the computer now shuts down OK.
Nice :slight_smile:
