Pianoteq zip file doen't extract- SOLVED
I downloaded this to my Peppermint laptop, but when I tried to extract it a box came up saying there was no command to open it- what is up with that guys?
https://www.pianoteq.com/try
(I downloaded standard)
Hi Melissa
I downloaded the same file and it extracted ok
Once downloaded I went to the downloaded file right clicked then “Extract here” which extracted a folder called Pianoteq 5
Is that what your doing if not how are you attempting yo extract it ?
As I said I was doing that and a box says it won’t open see grab.
Try this…
Open a terminal and run:
sudo apt-get install p7zip-full
when that completes, try extracting the archive again.
It extracted in the netbook thanks Mark, which is the computer I would be using for my digital piano and pianoteq. The demo worked fine on the netbook (Mint) that I could see, but I have yet to figure out how to play the piano through it- that is a question for the pianoteq forum. It looks quite complicated, but then technology that is new to someone always appears that way!
