printing on network department printer from ubuntu
Hi, I’m trying to get Ubuntu (to which I am quite new), which I have installed on an older machine to print to a Panasonic DP C262. It’s set up that under WIN pcl you have an option to put code else it won’t print, under win PS and MAC PS there is a security app on the desktop in which you enter and then you can print but not otherwise. any ideas/workarounds woukd be greatly appreciated.
Thanks
The Panasonic DP-C262 should work in Ubuntu with the pxlmono driver:
http://www.openprinting.org/printer/Panasonic/Panasonic-DP-C262
But I doubt if there will be a way round the security application other than turning security off … as Panasonic don’t support Linux for this printer.
There’s a slight chance you may be able to get it to work in WINE … but I doubt it.
