problem with flashybrid...NEED HELP
hi,
i’m trying to install the flashybrid but when i enter the apt-get install flashybrid command the machine returns me this :
root@user-desktop:/home/user# apt-get install flashybrid
Reading package lists… Done
Building dependency tree
flashybrid is already the newest version.
1 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
debconf: DbDriver “config”: /var/cache/debconf/config.dat is locked by another process: Resource temporarily unavailable
Setting up flashybrid (0.15+nmu2) …
dpkg: error processing flashybrid (–configure):
subprocess post-installation script returned error exit status 1
flashybrid
E: Sub-process /usr/bin/dpkg returned an error code (1)
please help me…
debconf: DbDriver "config": /var/cache/debconf/config.dat is locked by another process
You cannot install from the command line whilst your packakage manager(s) or Update Manger are open … so make sure they are closed … then try again.
Although … it also seems to be telling you the flashbrid package is already installed, and the latest version.
