problem with John the ripper
I have problem with John the ripper. It works fine.
but I have deleted the executable file /usr/bin/john by mistake and then I can not do unshadow command any more to crack the passwords as follow:
[root@localhost ~]# cd john-1.7.6/run
[root@localhost run]# umask 077
[root@localhost run]# unshadow /etc/passwd /etc/shadow > mypasswd2
bash: unshadow: command not found
So what should I do to fix this problem
Why not download it again and follow the instructions in the /doc/INSTALL file contained in the john-1.7.6.tar.gz file?
You “may” not need to reinstall
If you haven’t actually deleted anything, you need to start commands with ./ because they haven’t been installed system-wide… or add the ~/john-1.7.6/run directory to the system path.
So taking your commands you posted above, they SHOULD read:
cd john-1.7.6/run
./umask 077
./unshadow /etc/passwd /etc/shadow > mypasswd2
