Problem with update manager (Resolved)
Update manager gave me a warning that there had been no update for 14 days.
So as requested I ran it manually.
I was told that 2 repositories were not responding so I ran a check on the best mirror for my location and yet again the same 2 repositories did not respond.
I was able to remove one but I can not find the following one listed in update manager.
http://us.archive.ubuntu.com/ubuntu/dists/edgy/universe/binary-i386/Packages
Dose anyone know it this repositories is still work and if not how to remove it.
Thanks in advance.
Erm… change to a UK mirror (Server for the United Kingdom) in Synaptic.
then close synaptic, and run:
and if you get errors, post what they are.
Also send the contents of /etc/apt/sources.list:
gedit /etc/apt/sources.list
and remind us which distro/version you are running ::slight_smile:
W: Failed to fetch http://us.archive.ubuntu.com/ubuntu/dists/edgy/universe/binary-i386/Packages 404 Not Found [IP: 91.189.92.169 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I got this whilst running the update.
Other readout you requested -
deb cdrom:[Ubuntu 11.04 Natty Narwhal - Release i386 (20110427.1)]/ natty main restricted
deb-src Index of /ubuntu/ natty main restricted #Added by software-properties
See UpgradeNotes - Community Help Wiki for how to upgrade to
newer versions of the distribution.
deb Index of /ubuntu/ natty main restricted
deb-src Index of /ubuntu/ natty multiverse universe #Added by software-properties
Major bug fix updates produced after the final release of the
distribution.
deb Index of /ubuntu/ natty-updates main restricted
deb-src Index of /ubuntu/ natty-updates restricted main multiverse universe #Added by software-properties
N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
team. Also, please note that software in universe WILL NOT receive any
review or updates from the Ubuntu security team.
deb Index of /ubuntu/ natty universe
deb Index of /ubuntu/ natty-updates universe
team, and may not be under a free licence. Please satisfy yourself as to
your rights to use the software. Also, please note that software in
multiverse WILL NOT receive any review or updates from the Ubuntu
security team.
deb Index of /ubuntu/ natty multiverse
deb Index of /ubuntu/ natty-updates multiverse
Uncomment the following two lines to add software from the ‘backports’
repository.
N.B. software from this repository may not have been tested as
extensively as that contained in the main release, although it includes
newer versions of some applications which may provide useful features.
Also, please note that software in backports WILL NOT receive any review
deb Index of /ubuntu natty-backports main restricted universe multiverse
deb-src Index of /ubuntu natty-backports main restricted universe multiverse
deb Index of /ubuntu/ natty-security main restricted
deb-src Index of /ubuntu/ natty-security restricted main multiverse universe #Added by software-properties
deb Index of /ubuntu/ natty-security universe
deb Index of /ubuntu/ natty-security multiverse
Uncomment the following two lines to add software from Canonical’s
‘partner’ repository.
This software is not part of Ubuntu, but is offered by Canonical and the
respective vendors as a service to Ubuntu users.
deb Index of /ubuntu natty partner
deb-src Index of /ubuntu natty partner
This software is not part of Ubuntu, but is offered by third-party
developers who want to ship their latest software.
deb Index of /ubuntu natty main
deb-src Index of /ubuntu natty main
deb Index of /ubuntu edgy universe
Running Ubuntu 11.04 Natty Narwhal - Release i386
Open sources.list for editing:
Find the line that reads:
deb http://us.archive.ubuntu.com/ubuntu edgy universe
(it's near the bottom)
and comment it out, so it reads:
# deb http://us.archive.ubuntu.com/ubuntu edgy universe
SAVE the file, then run:
and check for errors.
Ok worked like a dream lots of updates for me to install.
Why did this happen as it was working OK until now?
Thanks for your help.
I’m not sure… all I can tell you is that line is trying to access an “Edgy Eft” (Ubuntu 6.10) repository.
Maybe it was taken offline as edgy is “end of life”, but I’d be fairly sure it shouldn’t have been in your sources.list in the first place… you’ve already got the “natty universe” repo further up your sources.list
deb http://nl3.archive.ubuntu.com/ubuntu/ natty universe
So I have no idea how that line came to be there.
