Problems installing Peppermint 4
Just checked out the live usb version of Peppermint 4. I like it. I have tried twice to install it via the install bitton on the main page. When it reboots after finishing installation it goes to a startup screem which definately is not Peppermint 4 and the mouse pointer is stuck in the centre of the screen.
Any clues?
So you’re installing it via the icon on the desktop of the LiveCD ?
Is this a dual boot setup ?
If this is a laptop … what make model ?
I have tried installing from the desktop icon and from the menu on the boot scree.
Its not a dual boot.
Its a Samsung netbook 1gb ram 160hd model NC10.
Can you explain this a little better:
Did you attempt to keep your home folder from a previous install ?
Which install option did you use (eg. install over Peppermint 3)
Did you run the installer from the live session desktop icon … or from the initial “Try Peppermint” screen ?
(try it from the desktop icon)
I did not try to keep my home folder. I used the usb stick that I had been testing so that home folder may have had some changes.
As I said. I installed from the desktop icon also from the menu option when I booted from usb.
As for the screen it looks like one that you would go i to if you went into so called safe mode.
What does the screen say ?
It’s not the grub boot menu is it ? (blue box on a black background)
Hope this link helps.
That’s the login screen … select your username from the drop menu … enter your password … click Log In.
I wish it was that easy. :frowning:
The touchpad want work, but it does in the live mode.
use the tab key to select the correct field.
Or try a usb mouse for now
We’ll get to the touchpad once you can log in.
Ok. I am in. No touchpad. Dont have usb mouse on me.
Hit Ctrl+Alt+T to open a terminal.
Now try running:
sudo modprobe -r psmouse
sudo modprobe psmouse
any change ? … does the touchpad now work ?
Sorry to say no.
libkmod error
is that the full error ?
This is the best as I can do as I cannot paste and send from netbook.
Let’s try a full system update.
Can you connect to your router with an ethernet cable ← you’ll need to, as wireless won’t be set up yet.
Then run:
sudo apt-get upgrade
sudo apt-get dist-upgrade
After those complete … run:
sudo shutdown -P now
to power off the netbook.
Now fire it up again … any change ?
No. I am out. I have linked my mobile via usb wifi mode but it cant see it.
Also I only have wifi at home via my mobile.
I was wondering. In another post I replied to Emegra that I had updated Peppermint 4 live no problems. I wonder if there nay have been a corruption somewhere.
I have the iso on a disk with me. Do you think I should re do the usb live install?
Try this … run:
sudo updatedb
locate modules.dep.bin
is there any output ?
ifr so, screenshot it
I’m hoping modules.dep.bin will be liisted for the kernel that came with the LiveCD
3.8.0-23
Screenshot
