Problems installing virtualbox [solved]
I’m trying to install virtualbox in a new installation of Xubuntu, by following Mark’s advice in a different thread, which I’ve quoted below (because I don’t know how to reference the other thread here).
Everthing works until sudo apt install virtualbox-4.3, which gives the following errors
mike@xubuntu:~$ sudo apt install virtualbox-4.3
Reading package lists… Done
Building dependency tree
virtualbox-4.3 : Depends: libvpx1 (>= 1.0.0) but it is not installable
Recommends: libsdl-ttf2.0-0 but it is not going to be installed
mike@xubuntu:~$
I tried the following, but no luck…
mike@xubuntu:~$ sudo apt-get install libvpx1
[sudo] password for mike:
Package libvpx1 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libvpx1’ has no installation candidate
mike@xubuntu:~$
Where do I go from here, folks? This worked in Ubuntu 14.04.
TiA.
Maybe it is not working because of the old version?
They are on version 5.2
Have you tried the instructions here:
https://www.virtualbox.org/wiki/Linux_Downloads
Thanks SeZo,
I followed the link, downloaded the Ubuntu 16.04 files, accepted the option to open with the package installer and bingo! I can now open virtualbox 5.2.22.
My next task will be to get it to recognize one or two VMs I created before reinstalling Xubuntu and upgrading to 5.2.22. I’ll leave this thread open for the moment since it’s the obvious place for any questions I might have on that score.
Ok. I got vb to recognise one of my vms, so I’m marking this solved now.
Thanks again, SeZo.
