Pulseaudio gone from Menu (SOLVED)
Have done something daft… :‘( :’( :‘( :’(
Pulseaudio has gone from Sound and Video Menu.
Audio working fine,just no menu entry.
Jocklad
Try:
sudo apt-get install --reinstall pulseaudio pulseaudio-utils pavucontrol
Yes that did it Mark.
Again many thanks.
Jocklad :slight_smile: :slight_smile: :slight_smile: :slight_smile: :slight_smile:
You’re welcome :slight_smile:
