Python 3
Hi Guys
I would like to have Python 3 installed on my PC but the repos only have v2.7.4, I’ve been on the Python website but I can’t find a packaged version for Linux, I’ve downloaded v3.4 tar.xz, but I’m not familiar with compiling from source.
Can anyone tell me where I can find a packedged version or how I compile the tarbal
Many thanks
python3 is probably already installed (as well as python 2.7)
You’d run a python 2.7 app with:
python myapp.py
or a pthoyn3 app with:
python3 myapp.py
an executable python script is told which python environment to use by having
#!/usr/bin/env python2.7
#!/usr/bin/env python3
as the FIRST line (shebang line) in the script.
Easiest way to check if python3 is installed … run:
python3 --version
if that returns a version … it’s installed :wink:
If you’re going to be using IDLE for python3 … install the idle3 package (in the repos).
Thanks Mark that’s sorted it
I already had v3,3,1 installed and IDLE3 was in the repos as you suggested
Once again thanks for your help
