Raid 10
Hi Guys,
just wanted to confirm some thing am i right in thinking that you require a 4 drive minimum for raid 10. Ive have recently seen conflicting information on this subject.
Correct.
Absolute minimum of 4, since the raid10 array is a stripe of mirrors (raid 0 overseeing multiple raid 1 arrays) the number of physical disks clearly has to be an even number (not including online spares).
Saying that, I have never set up such a small raid10 array. Typically, the arrays I set up for customers are 16 spindles.
EDIT: Ahh, I think I see what you’re getting at - as spookily enough I have just logged onto an HP Smart Array BIOS and it clearly says RAID 1+0 on a 2 disk set. To me, that’s just simple mirroring…
I’m afraid RAID10 can be set up on any number of disks, so long as you have at least two. I currently have 2,3 and 5 drive sets in operation.
For best performance, use this command to set up;
mdadm --create /dev/md --chunk -p f2 -n {partitions}
Where is a free device, say “0”
Where is your chunk size, currently I’m [typically] using 512 in workstations and 1024 in servers
Where is the number of devices in the RAID
and {partitions} is a space separated list of devices to include (where the number of devices == )
Note, RAID10 and RAID1+0 are two different things … RAID10 on two disks is essentially RAID1 with one critical difference, it will allow you to stripe read (see the -p f2 above) whereas RAID1 will not.
(i.e. RAID 10 tried to double your read performance)
Sample of RAID10 in action;
root@core6:~# cat /proc/mdstat Personalities : [linear] [multipath] [raid0] [raid1] [raid6] [raid5] [raid4] [raid10] md0 : active raid10 sdc2[0] sde2[1] 31461376 blocks 1024K chunks 2 far-copies [2/2] [UU]
md2 : active raid10 sdc5[0] sda5[3] sdb5[4] sde5[2] sdd5[1]
720916480 blocks 1024K chunks 2 far-copies [5/5] [UUUUU]
md3 : active raid10 sde6[1] sdc6[0]
113321984 blocks 256K chunks 2 far-copies [2/2] [UU]
md1 : active raid10 sde3[1] sdc3[0]
6297088 blocks 256K chunks 2 far-copies [2/2] [UU]
Yeah, the kernel level RAID10 is a bizarre implementation of RAID10. I have no clue how this works in practice with an odd number of spindles…
Works tho’, see disk performance here;
http://linuxforums.org.uk/general-discussion/the-linux-pc-quick-review/msg26562/?topicseen#new
You know, those stats aren’t bad at all - especially as they are cheap & nasty.
I sneakily ran the same command on an HP DL580 G5, on a hardware RAID10 array (Smart Array P400 controller) consisting of 8 x 300Gb SAS disks @ 15,000rpm:
[root@ ~]# hdparm -tT /dev/mapper/vgDataInternal-lvDataInternal
/dev/mapper/vgDataInternal-lvDataInternal:
Timing cached reads: 8804 MB in 2.00 seconds = 4406.48 MB/sec
Timing buffered disk reads: 566 MB in 3.01 seconds = 188.35 MB/sec
EDIT: Same machine, second controller (also P400 Smart Array), this time hardware RAID5 (8 x 75GB SAS @ 15,000rpm):
Timing cached reads: 8764 MB in 2.00 seconds = 4385.79 MB/sec Timing buffered disk reads: 140 MB in 3.03 seconds = 46.25 MB/sec
I ran the RAID5 test several times, and the highest buffered disk read was 50.4 MB/sec
Appreciate the input on that guys.
Wow! That really is slow given the kit spec!
This is “the beast” running 9 busy(ish) virtuals under KVM … (one of which is mail.linux.co.uk … )
root@core6:~# hdparm -tT /dev/md2
/dev/md2:
Timing cached reads: 6724 MB in 2.00 seconds = 3362.74 MB/sec
Timing buffered disk reads: 1120 MB in 3.02 seconds = 370.88 MB/sec
Just to clarify, this is 5 x SATA II on a RAID10 … (!)
root@core6:~# virsh list Id Name State ---------------------------------- 2 dns2 running 3 gluster2 running 4 linuxmail running 5 nx1 running 6 pabx_sax running 7 pera2 running 8 wp1 running 9 running 10 running
