Ralink RT2870 based USB Wireless N adapters (Ubuntu)
I can’t believe! I fixed it!
I just heated rt5370 with my Lukey rework station, only F-2000 flux paste was used!
And dongle works again )
Nice, so the drivers are working too ?
Mark its me again from 2 pages back - I’m updating my Ralink driver by doing a remove and an install as you recommended 2 pages back everytome Linux updates. I’m getting absolutely dumbfounded by Linux’s horrific reliability.
Any commands of mine containing sudo are magically “hanging”.
Its similar to what this chap experiences:
So my machine is useless now. Any hints?
A restart fixed it.
Seriously this operating system is way too hyped
Hi Mark, this always used to work for me (your remove command should actually write …sta/1.0 and not …sta/1.02).
Now it has stopped working.
When I try the install (the second command) I get a bad exit status of 2. it says the binary package is not found.
Looking at the detailed log, I get this:
In function ‘memcpy’, inlined from ‘rt_ioctl_iwaplist’ at /var/lib/dkms/mt7610u_sta/1.0/build/os/linux/../../os/linux/sta_ioctl.c:696:2: ./include/linux/string.h:305:4: error: call to ‘__read_overflow2’ declared with attribute error: detected read beyond size of object passed as 2nd parameter __read_overflow2(); ^ scripts/Makefile.build:308: recipe for target '/var/lib/dkms/mt7610u_sta/1.0/build/os/linux/../../os/linux/sta_ioctl.o' failed make[2]: *** [/var/lib/dkms/mt7610u_sta/1.0/build/os/linux/../../os/linux/sta_ioctl.o] Error 1 make[2]: *** Waiting for unfinished jobs.... Makefile:1550: recipe for target '_module_/var/lib/dkms/mt7610u_sta/1.0/build/os/linux' failed make[1]: *** [_module_/var/lib/dkms/mt7610u_sta/1.0/build/os/linux] Error 2 make[1]: Leaving directory '/usr/src/linux-headers-4.13.0-32-generic' Makefile:394: recipe for target 'LINUX' failed make: *** [LINUX] Error 2
Any ideas how to resolve this?
Okay let’s start from scratch…
Uninstall and remove the old dkms driver
sudo dkms uninstall mt7610u_sta/1.0
sudo dkms remove mt7610u_sta/1.0 --all
and remove the dmks source:
sudo rm -rv /usr/src/mt7610u_sta-1.0
delete the old downloaded driver source
sudo rm -rv ~/mt7610u-driver
then re-download the driver:
mkdir ~/mt7610u-driver
cd ~/mt7610u-driver
git clone https://github.com/xtknight/mt7610u-linksys-ae6000-wifi-fixes.git
cd ~/mt7610u-driver/mt7610u-linksys-ae6000-wifi-fixes
sudo cp -R . /usr/src/mt7610u_sta-1.0
sudo dkms add mt7610u_sta/1.0
sudo dkms build mt7610u_sta/1.0
sudo dkms install mt7610u_sta/1.0
sudo modprobe mt7610u_sta
did wireless spring to life ?
As soon as I hit enter on the last command, I get a “system programme problem detected” prompt where it asks me whether I want to report the problem.
Also when I reboot the same prompt comes up as soon as loading up.
Anyway, what has changed since before is I do see that my wifi wireless modem shows on the top right but after clicking it I get more prompts including “connection activation failed” and “(2) active connection removed before it was initialised”
Im trying to see why that is
New kernel patched for Spectre/Meltdown … the new kernel obviously doesn’t like that driver once compiled.
Let’s try another driver
mkdir ~/mt7610u
cd ~/mt7610u
git clone https://github.com/ulli-kroll/mt7610u.git
cd ~/mt7610u/mt7610u
make
sudo make installfw
sudo rm -rv /etc/Wireless/RT2870STA
sudo mkdir /etc/Wireless/RT2870STA
sudo cp -v RT2870STA.dat /etc/Wireless/RT2870STA/
sudo install -d /lib/modules/$(uname -r)/kernel/drivers/net/wireless/
sudo install -m 644 -c mt7610u.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless/
sudo depmod -a $(uname -r)
sudo rmmod mt7610u_sta
To UNINSTALL
sudo rmmod mt7610u
sudo rm -v /lib/modules/$(uname -r)/kernel/drivers/net/wireless/mt7610u.ko
sudo rm -v /lib/firmware/mt7610u.bin
sudo rm -v /lib/firmware/mt7650u.bin
Hello :),
i have a Hama rt2870 based Wlan Adapter. (00062740)
I was trying to change PID/VID but it didtn work out : ra0 no private ioctls.
So i was trying to compile the driver wich also didnt work, dont know what to do next. ( driver: Dropbox - 2010_0709_RT2870_Linux_STA_v2.4.0.1.tar.bz2 - Simplify your life )
4.15.0-29-generic
Bus 001 Device 004: ID 148f:2870 Ralink Technology, Corp. RT2870 Wireless Adapter
Bus 001 Device 002: ID 80ee:0021 VirtualBox USB Tablet
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
rt2800usb 32768 0
rt2x00usb 20480 1 rt2800usb
rt2800lib 114688 1 rt2800usb
rt2x00lib 53248 3 rt2800lib,rt2800usb,rt2x00usb
mac80211 778240 3 rt2800lib,rt2x00lib,rt2x00usb
cfg80211 622592 2 rt2x00lib,mac80211
need to restart Oracle to reproduce the make errors
edit: ps: forgot to say : i am new with linux
make
tester@tester-VirtualBox:~/2010_0709_RT2870_Linux_STA_v2.4.0.1$ sudo su
[sudo] password for tester:
root@tester-VirtualBox:/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1# make
make -C tools
make[1]: Entering directory ‘/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/tools’
gcc -g bin2h.c -o bin2h
make[1]: Leaving directory ‘/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/tools’
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/tools/bin2h
cp -f os/linux/Makefile.6 /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/Makefile
make -C /lib/modules/4.15.0-29-generic/build SUBDIRS=/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux modules
make[1]: Entering directory ‘/usr/src/linux-headers-4.15.0-29-generic’
Makefile:976: “Cannot use CONFIG_STACK_VALIDATION=y, please install libelf-dev, libelf-devel or elfutils-libelf-devel”
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_md5.o
In file included from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/include/rtmp_os.h:42:0,
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/include/rt_config.h:72,
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_md5.c:28:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_md5.c: In function ‘MD5Final’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_md5.c:322:32: warning: argument to ‘sizeof’ in ‘memset’ call is the same expression as the destination; did you mean to dereference it? [-Wsizeof-pointer-memaccess]
NdisZeroMemory(pCtx, sizeof(pCtx)); // memory free
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/include/os/rt_linux.h:452:76: note: in definition of macro ‘NdisZeroMemory’
fine NdisZeroMemory(Destination, Length) memset(Destination, 0, Length)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_md5.c: In function ‘SHAFinal’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_md5.c:621:32: warning: argument to ‘sizeof’ in ‘memset’ call is the same expression as the destination; did you mean to dereference it? [-Wsizeof-pointer-memaccess]
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_sha2.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_hmac.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c: In function ‘WscEncryptData’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c:1522:1: warning: the frame size of 1400 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c: In function ‘WscDecryptData’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c:1592:1: warning: the frame size of 1400 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c: In function ‘AES_GTK_KEY_WRAP’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c:2265:1: warning: the frame size of 1616 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c: In function ‘AES_GTK_KEY_UNWRAP’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_aes.c:2348:1: warning: the frame size of 1136 bytes is larger than 1024 bytes [-Wframe-larger-than=]
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/crypt_arc4.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.o
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c:39:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c: In function ‘MlmeResetRalinkCounters’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c:896:6: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(UINT32)&pAd->RalinkCounters.OneSecEnd -
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c:897:6: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
(UINT32)&pAd->RalinkCounters.OneSecStart);
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c: In function ‘BssTableSetEntry’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c:5739:39: warning: operation on ‘Tab->BssOverlapNr’ may be undefined [-Wsequence-point]
Tab->BssOverlapNr = (Tab->BssOverlapNr++) % MAX_LEN_OF_BSS_TABLE;
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c: In function ‘BssTableSortByRssi’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/mlme.c:6100:1: warning: the frame size of 1720 bytes is larger than 1024 bytes [-Wframe-larger-than=]
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wep.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/action.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_data.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/rtmp_init.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_tkip.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_aes.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_sync.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_sync.c: In function ‘ScanNextChannel’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_sync.c:591:3: warning: this ‘if’ clause does not guard… [-Wmisleading-indentation]
if (OPSTATUS_TEST_FLAG(pAd, fOP_STATUS_DOZE))
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_sync.c:595:4: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
if (pAd->StaCfg.Psm == PWR_SAVE)
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/eeprom.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_sanity.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c: In function ‘GetEncryptType’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:2073:5: warning: this ‘if’ clause does not guard… [-Wmisleading-indentation]
if(enc == Ndis802_11Encryption3Enabled)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:2075:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
if(enc == Ndis802_11Encryption4Enabled)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c: In function ‘GetAuthMode’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:2085:5: warning: this ‘if’ clause does not guard… [-Wmisleading-indentation]
if(auth == Ndis802_11AuthModeShared)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:2087:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
if(auth == Ndis802_11AuthModeAutoSwitch)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:2097:5: warning: this ‘if’ clause does not guard… [-Wmisleading-indentation]
if(auth == Ndis802_11AuthModeWPA2PSK)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:2099:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
if(auth == Ndis802_11AuthModeWPA1WPA2)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c: In function ‘Show_PMK_Proc’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:3909:5: warning: this ‘for’ clause does not guard… [-Wmisleading-indentation]
for (idx = 0; idx < 32; idx++)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_info.c:3912:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘for’
return 0;
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_cfg.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wpa.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wpa.c: In function ‘WPAStart2WayGroupHS’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wpa.c:1198:5: warning: this ‘if’ clause does not guard… [-Wmisleading-indentation]
if ((!pEntry) || !IS_ENTRY_CLIENT(pEntry))
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wpa.c:1203:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘if’
os_alloc_mem(NULL, (PUCHAR *)&mpool, TX_EAPOL_BUFFER);
In file included from ./include/linux/bitmap.h:9:0,
from ./include/linux/cpumask.h:12,
from ./arch/x86/include/asm/cpumask.h:5,
from ./arch/x86/include/asm/msr.h:11,
from ./arch/x86/include/asm/processor.h:21,
from ./arch/x86/include/asm/cpufeature.h:5,
from ./arch/x86/include/asm/thread_info.h:53,
from ./include/linux/thread_info.h:38,
from ./arch/x86/include/asm/preempt.h:7,
from ./include/linux/preempt.h:81,
from ./include/linux/spinlock.h:51,
from ./include/linux/seqlock.h:36,
from ./include/linux/time.h:6,
from ./include/linux/stat.h:19,
from ./include/linux/module.h:10,
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/include/os/rt_linux.h:40,
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/include/rtmp_os.h:42,
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wpa.c:38:
./include/linux/string.h:359:9: warning: argument 2 null where non-null expected [-Wnonnull]
return __builtin_memmove(p, q, size);
./include/linux/string.h:359:9: note: in a call to built-in function ‘__builtin_memmove’
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_wpa.c: In function ‘PeerPairMsg2Action’:
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/dfs.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/spectrum.o
from /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/spectrum.c:39:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/spectrum.c: In function ‘PeerMeasureReportAction’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/spectrum.c:1977:29: warning: format ‘%d’ expects argument of type ‘int’, but argument 3 has type ‘long unsigned int’ [-Wformat=]
DBGPRINT(RT_DEBUG_ERROR, (“%s unable to alloc memory for measure report buffer (size=%d).\n”, FUNCTION, sizeof(MEASURE_RPI_REPORT)));
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/include/os/rt_linux.h:621:16: note: in definition of macro ‘DBGPRINT_RAW’
printk Fmt;
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/spectrum.c:1977:3: note: in expansion of macro ‘DBGPRINT’
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/rtmp_timer.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/rt_channel.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_profile.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_asic.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/cmm_cmd.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/assoc.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/auth.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/auth_rsp.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.c: In function ‘PeerBeaconAtScanAction’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.c:764:1: warning: the frame size of 1280 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.c: In function ‘PeerBeaconAtJoinAction’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.c:1094:1: warning: the frame size of 1328 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.c: In function ‘PeerBeacon’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sync.c:1764:1: warning: the frame size of 1320 bytes is larger than 1024 bytes [-Wframe-larger-than=]
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sanity.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/rtmp_data.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/rtmp_data.c: In function ‘STAFindCipherAlgorithm’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/rtmp_data.c:1497:6: warning: this ‘else’ clause does not guard… [-Wmisleading-indentation]
else
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/rtmp_data.c:1500:3: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
if (RTMP_GET_PACKET_EAPOL(pTxBlk->pPacket))
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/connect.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/connect.c: In function ‘CntlOidScanProc.part.0’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/connect.c:355:1: warning: the frame size of 1760 bytes is larger than 1024 bytes [-Wframe-larger-than=]
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/wpa.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/ags.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sta_cfg.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sta_cfg.c: In function ‘Set_EncrypType_Proc’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sta_cfg.c:679:5: warning: this ‘else’ clause does not guard… [-Wmisleading-indentation]
else
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/sta/sta_cfg.c:682:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
if (pAd->StaCfg.BssType == BSS_ADHOC)
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/common/rtmp_init_inf.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/rt_profile.o
CC [M] /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.o
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘rt_ioctl_siwfreq’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:174:5: warning: this ‘else’ clause does not guard… [-Wmisleading-indentation]
else
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:177:2: note: …this statement, but the latter is misleadingly indented as if it were guarded by the ‘else’
return 0;
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘rt_ioctl_siwencode’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:1479:6: warning: suggest parentheses around operand of ‘!’ or change ‘&’ to ‘&&’ or ‘!’ to ‘~’ [-Wparentheses]
if(!erq->flags & IW_ENCODE_MODE)
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘rt_private_show’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:1830:78: error: macro “DATE” might prevent reproducible builds [-Werror=date-time]
sprintf(extra, “Driver version-%s, %s %s\n”, STA_DRIVER_VERSION, DATE, TIME );
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:1830:88: error: macro “TIME” might prevent reproducible builds [-Werror=date-time]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘rt_ioctl_siwmlme’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:1979:1: warning: the frame size of 1664 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘rt_ioctl_iwaplist’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:599:1: warning: the frame size of 1312 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘RTMPIoctlMAC’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:5836:1: warning: the frame size of 1352 bytes is larger than 1024 bytes [-Wframe-larger-than=]
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c: In function ‘RTMPIoctlE2PROM’:
/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.c:6035:1: warning: the frame size of 1352 bytes is larger than 1024 bytes [-Wframe-larger-than=]
cc1: some warnings being treated as errors
scripts/Makefile.build:332: recipe for target ‘/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.o’ failed
make[2]: *** [/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux/…/…/os/linux/sta_ioctl.o] Error 1
Makefile:1552: recipe for target ‘module/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux’ failed
make[1]: *** [module/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux] Error 2
make[1]: Leaving directory ‘/usr/src/linux-headers-4.15.0-29-generic’
Makefile:243: recipe for target ‘LINUX’ failed
make install
root@tester-VirtualBox:/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1# make install
make -C /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux -f Makefile.6 install
make[1]: Entering directory ‘/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux’
mkdir: cannot create directory ‘/etc/Wireless’: File exists
rm -rf /etc/Wireless/RT2870STA
cp /home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/RT2870STA.dat /etc/Wireless/RT2870STA/.
install -d /lib/modules/4.15.0-29-generic/kernel/drivers/net/wireless/
install -m 644 -c rt2870sta.ko /lib/modules/4.15.0-29-generic/kernel/drivers/net/wireless/
install: cannot stat ‘rt2870sta.ko’: No such file or directory
Makefile.6:140: recipe for target ‘install’ failed
make[1]: *** [install] Error 1
make[1]: Leaving directory ‘/home/tester/2010_0709_RT2870_Linux_STA_v2.4.0.1/os/linux’
Makefile:281: recipe for target ‘install’ failed
make: *** [install] Error 2
Hey guys
Sorry for bringing back the topic but I’ve searched an answer for 2 days now but still can’t figure it out.
I pretty much tried everything in this thread but nothing has worked yet
I just installed Ubuntu 18.04.LTS on one of my laptop. I’m trying to install the driver for my ALFA AWUS036NH but it’s a nightmare. The laptop think it’s the rt2800 driver, so when I turn off the built-in wifi, the wireless card shut down. I’ve blacklist the rt2800usb but I can’t install the rt2870 driver at all.
It does show up when I type
lsusb
Bus 001 Device 003: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
Let me know what you need from my Terminal!
