Ralink wireless card does not work [SOLVED]
I’m not 100% convinced this is a driver issue … have you tried installing the chromium browser:
sudo apt-get install chromium-browser
then disconnecting your wired connection, and trying Chromium.
I’d just like to rule out Firefox somehow causing this.
Same thing ! I really don’t know what to think
OK, those drivers were only really tested with 12.04 … not 12.10.
What kernel is 12.10 running:
uname -a
It may be that a kernel downgrade, then recompiling the driver might work
Did they compile without error in 12.10 ?
Linux iLinux 3.5.0-18-generic #29-Ubuntu SMP Fri Oct 19 10:26:51 UTC 2012 x86_64 x86_64 x86_64 GNU/Linux
Yes they compile without error, I even redone it with a fresh install of ubuntu just to make sure !!
Is there another distribution that have the driver by default or something , I just don’t want to be with windows !
AFAIK, there will be no distro that has these drivers by default, as they aren’t even properly supported by Ralink … I had to add the VENDOR:PRODUCT ID strings to the ralink drivers to get them working in 12.04.
It won’t be hard to install a 3.2 series kernel, then recompile the drivers … this will NOT remove the 12.10 kernel, it will ust give you an OPTION to boot the older kernel.
I’ll write up instructions tomorrow and post them here, but I’m off to bed now … it’s 03:45 here :wink:
OK, create a directory in your Home directory called kernal-install:
mkdir ~/kernal-install
change directory to it:
cd ~/kernal-install
now download the 3 (64bit) kernel files necessary (we’re going to go for 3.2.0-33, current in 12.04):
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.2.33-precise/linux-headers-3.2.33-030233-generic_3.2.33-030233.201210310701_amd64.deb
then:
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.2.33-precise/linux-headers-3.2.33-030233_3.2.33-030233.201210310701_all.deb
then:
wget http://kernel.ubuntu.com/~kernel-ppa/mainline/v3.2.33-precise/linux-image-3.2.33-030233-generic_3.2.33-030233.201210310701_amd64.deb
Now install them with:
sudo dpkg -i *.deb
When installed (and you’re back at an $ prompt) … REBOOT.
If this is NOT a dual boot system, you’ll have to hit and hold the Shift key immediately after the BIOS POST screen to access the GRUB boot menu … once aat the GRUB boot menu, look for the option to boot into the 3.2 kernel (maybe in a sub-menu called something like “Other Linux Versions” … highlight it, and hit enter to boot to it.
When at the desktop, open a terminal and run:
uname -a
to check you’re using the 3.2 kernel, NOT the 3.5 kernel.
Once you’re sure … follow the original instructions to download, compile, and install the drivers.
If it works … let me know, and I’ll tell you how to set the 3.2 kernel as the default kernel to boot at system startup (so you don’t have to keep selecting it at the GRUB menu every boot).
Rebooting WITHOUT selecting the 3.2 kernel at the GRUB menu should boot the 3.5 kernel.
Thank you so much it’s working the only problem I have , My cursor is acting all weird . it’s always disappear on screen ? Do you know how to fix that ?
And how to put that kernel as default ?
Thanks again !! You save me from an awful windows 8 laptop haha
One at a time … you’ll probably have to reinstall the graphics drivers (if you’re using proprietary drivers).
Start “Additional Drivers” … then if any graphics drivers are listed, de-activate them … then reactivate them.
But if I were you I’d give consideration to either replacing Ubuntu 12.10 with 12.04 LTS … which will be supported for longer anyway, as it’s a “Long Term Support” release.
(12.04 has 4 and a half years support left … 12.10 has about 17 months … hopefully Ralink will have released a new driver before 12.04 runs out … or your card will be added to the rt2800pci open source drivers).
just buy one of these:
http://www.amazon.com/Edimax-EW-7811Un-Wireless-Adapter-Wizard/dp/B005CLMJLU
and sticking with the 3.5 kernel
(that Edimax EW-7811Un Nano works “out-of-the-box” n 12.04, so should in 12.10 to)
If you open “Additional Drivers” … is anything listed ?
We’ll get to making 3.2 default in a bit … though as I said you’d probably just be better off with Ubuntu12.04 … which you can get from there if you wish:
http://releases.ubuntu.com/precise/ubuntu-12.04.1-desktop-amd64.iso
I’ve listen to your advice I finaly install 12.04 ! Thank you so much for your support !
One last question what is better
AMD/ATI proprietary FGLRX graphic driver or
AMD/ATI proprietary FGLRX graphic (post-release updates)
and by installing 12.04 I don’t have the cursors problem anymore :slight_smile:
It’s not really important … go with “post release updates” unless you have a problem with them :wink:
Glad to hear you’re now sorted.
Ooops, nearly forgot … you’re most welcome :slight_smile:
I have the same problem with ubuntu 12.04. Instalation works ok, but can not connect to wireless network. Can you help me?
rad@rad-ZBOX-ID82:~$ sudo lshw -C network
[sudo] password for rad:
  *-network
       physical id: 0
       bus info: pci@0000:01:00.0
       logical name: eth0
       version: 06
       serial: 00:01:2e:47:95:d3
       capacity: 1Gbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=10.0.8.82 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
       resources: irq:48 ioport:e000(size=256) memory:f0004000-f0004fff memory:f0000000-f0003fff
  *-network
       product: Ralink corp.
       vendor: Ralink corp.
       physical id: 0
       bus info: pci@0000:03:00.0
       logical name: ra0
       version: 00
       serial: 94:db:c9:a9:a5:bf
       width: 32 bits
       configuration: broadcast=yes driver=RALINK WLAN latency=0 multicast=yes wireless=Ralink STA
       resources: irq:19 memory:f7d40000-f7d4ffff memory:f7d30000-f7d3ffff
rad@rad-ZBOX-ID82:~$ ifconfig
eth0      Link encap:Ethernet  HWadr 00:01:2e:47:95:d3
          inet adr:10.0.8.82  Všesměr:10.0.8.255  Maska:255.255.255.0
          inet6-adr: fe80::201:2eff:fe47:95d3/64 Rozsah:Linka
          AKTIVOVÁNO VŠESMĚROVÉ_VYSÍLÁNÍ BĚŽÍ MULTICAST  MTU:1500  Metrika:1
          RX packets:12236 errors:0 dropped:0 overruns:0 frame:0
          TX packets:22371 errors:0 dropped:0 overruns:0 carrier:0
          kolizí:0 délka odchozí fronty:1000
          Přijato bajtů: 2165999 (2.1 MB) Odesláno bajtů: 23899527 (23.8 MB)
          Přerušení:48 Vstupně/Výstupní port:0x6000
lo        Link encap:Místní smyčka
          inet adr:127.0.0.1  Maska:255.0.0.0
          inet6-adr: ::1/128 Rozsah:Počítač
          AKTIVOVÁNO SMYČKA BĚŽÍ  MTU:16436  Metrika:1
          RX packets:57231 errors:0 dropped:0 overruns:0 frame:0
          TX packets:57231 errors:0 dropped:0 overruns:0 carrier:0
          kolizí:0 délka odchozí fronty:0
          Přijato bajtů: 100526313 (100.5 MB) Odesláno bajtů: 100526313 (100.5 MB)
ra0       Link encap:Ethernet  HWadr 94:db:c9:a9:a5:bf
          inet6-adr: fe80::96db:c9ff:fea9:a5bf/64 Rozsah:Linka
          AKTIVOVÁNO VŠESMĚROVÉ_VYSÍLÁNÍ MULTICAST  MTU:1500  Metrika:1
          TX packets:3970 errors:0 dropped:0 overruns:0 carrier:0
          Přijato bajtů: 0 (0.0 B) Odesláno bajtů: 0 (0.0 B)
          Přerušení:19
rad@rad-ZBOX-ID82:~$ iwconfig
ra0       Ralink STA  ESSID:""  Nickname:"RT3290STA"
          Mode:Auto  Frequency=2.412 GHz  Access Point: Not-Associated
          Bit Rate:1 Mb/s
          RTS thr:off   Fragment thr:off
          Link Quality=70/100  Signal level:0 dBm  Noise level:0 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
eth0      no wireless extensions.
rad@rad-ZBOX-ID82:~$ iwlist scanning
ra0       No scan results
rad@rad-ZBOX-ID82:~$ rfkill list
rad@rad-ZBOX-ID82:~$ lsusb
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 002: ID 046d:c31c Logitech, Inc. Keyboard K120 for Business
Bus 002 Device 003: ID 046d:c03e Logitech, Inc. Premium Optical Wheel Mouse (M-BT58)
rad@rad-ZBOX-ID82:~$ lsmod
Module                  Size  Used by
pci_stub               12622  1
vboxpci                23237  0
vboxnetadp             13382  0
vboxnetflt             23478  0
vboxdrv               287082  3 vboxpci,vboxnetadp,vboxnetflt
nfsd                  277884  2
nfs                   356470  0
snd_hda_codec_hdmi     32474  1
snd_hda_codec_realtek   224173  1
bnep                   18281  2
parport_pc             32866  0
ppdev                  17113  0
rfcomm                 47604  0
lockd                  90326  2 nfsd,nfs
fscache                61529  1 nfs
auth_rpcgss            53380  2 nfsd,nfs
bluetooth             180153  10 bnep,rfcomm
ip6t_LOG               16974  4
nfs_acl                12883  2 nfsd,nfs
binfmt_misc            17540  1
xt_hl                  12521  6
ip6t_rt                12558  3
sunrpc                245863  6 nfsd,nfs,lockd,auth_rpcgss,nfs_acl
nf_conntrack_ipv6      13906  7
nf_defrag_ipv6         13412  1 nf_conntrack_ipv6
ipt_REJECT             12576  1
ipt_LOG                12919  5
xt_limit               12711  12
xt_tcpudp              12603  24
xt_addrtype            12713  4
snd_hda_intel          33773  3
snd_hda_codec         127706  3 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel
snd_hwdep              17764  1 snd_hda_codec
xt_state               12578  14
snd_pcm                97275  3 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
snd_seq_midi           13324  0
ip6table_filter        12815  1
snd_rawmidi            30748  1 snd_seq_midi
snd_seq_midi_event     14899  1 snd_seq_midi
rt3290sta            1182379  1
ip6_tables             27864  3 ip6t_LOG,ip6t_rt,ip6table_filter
snd_seq                61929  2 snd_seq_midi,snd_seq_midi_event
nf_conntrack_netbios_ns    12665  0
nf_conntrack_broadcast    12589  1 nf_conntrack_netbios_ns
snd_timer              29990  2 snd_pcm,snd_seq
snd_seq_device         14540  3 snd_seq_midi,snd_rawmidi,snd_seq
nf_nat_ftp             12704  0
nf_nat                 25891  1 nf_nat_ftp
snd                    79041  16 snd_hda_codec_hdmi,snd_hda_codec_realtek,snd_hda_intel,snd_hda_codec,snd_hwdep,snd_pcm,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
nf_conntrack_ipv4      19716  9 nf_nat
i915                  477602  3
drm_kms_helper         46978  1 i915
drm                   241971  4 i915,drm_kms_helper
mei                    41616  0
nf_defrag_ipv4         12729  1 nf_conntrack_ipv4
i2c_algo_bit           13423  1 i915
soundcore              15091  1 snd
snd_page_alloc         18529  2 snd_hda_intel,snd_pcm
nf_conntrack_ftp       13452  1 nf_nat_ftp
nf_conntrack           81926  8 nf_conntrack_ipv6,xt_state,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_nat_ftp,nf_nat,nf_conntrack_ipv4,nf_conntrack_ftp
video                  19596  1 i915
lp                     17799  0
psmouse                97485  0
parport                46562  3 parport_pc,ppdev,lp
joydev                 17693  0
serio_raw              13211  0
iptable_filter         12810  1
mac_hid                13253  0
ip_tables              27473  1 iptable_filter
x_tables               29891  13 ip6t_LOG,xt_hl,ip6t_rt,ipt_REJECT,ipt_LOG,xt_limit,xt_tcpudp,xt_addrtype,xt_state,ip6table_filter,ip6_tables,iptable_filter,ip_tables
usbhid                 47238  0
hid                    99636  1 usbhid
r8169                  62154  0
Hi powery, and welcome to the forum :slight_smile:
Can you run:
sudo lspci -vnn
then look through the output for the section concerning your wireless adapter … and post it back here
EXAMPLE -
03:00.0 Ethernet controller [0200]: Atheros Communications Inc. AR242x / AR542x Wireless Network Adapter (PCI-Express) [168c:001c] (rev 01)
	Subsystem: Foxconn International, Inc. Device [105b:e008]
	Flags: bus master, fast devsel, latency 0, IRQ 18
	Memory at 75200000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: [40] Power Management version 2
	Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit-
	Capabilities: [60] Express Legacy Endpoint, MSI 00
	Capabilities: [90] MSI-X: Enable- Count=1 Masked-
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [140] Virtual Channel
	Kernel driver in use: ath5k
	Kernel modules: ath5k
The whole output:
rad@rad-ZBOX-ID82:~$ sudo lspci -vnn
00:00.0 Host bridge [0600]: Intel Corporation 2nd Generation Core Processor Family DRAM Controller [8086:0104] (rev 09)
        Subsystem: ZOTAC International (MCO) Ltd. Device [19da:a206]
        Capabilities: [e0] Vendor Specific Information: Len=0c <?>
        Kernel driver in use: agpgart-intel
00:02.0 VGA compatible controller [0300]: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller [8086:0116] (rev 09) (prog-if 00 [VGA controller])
        Flags: bus master, fast devsel, latency 0, IRQ 50
        Memory at f7800000 (64-bit, non-prefetchable) [size=4M]
        Memory at e0000000 (64-bit, prefetchable) [size=256M]
        I/O ports at f000 [size=64]
        Expansion ROM at <unassigned> [disabled]
        Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [d0] Power Management version 2
        Capabilities: [a4] PCI Advanced Features
        Kernel driver in use: i915
        Kernel modules: i915
00:16.0 Communication controller [0780]: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 [8086:1c3a] (rev 04)
        Flags: bus master, fast devsel, latency 0, IRQ 49
        Memory at f7f09000 (64-bit, non-prefetchable) [size=16]
        Capabilities: [50] Power Management version 3
        Capabilities: [8c] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Kernel driver in use: mei
        Kernel modules: mei
00:1a.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 [8086:1c2d] (rev 05) (prog-if 20 [EHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 16
        Memory at f7f07000 (32-bit, non-prefetchable) [size=1K]
        Capabilities: [50] Power Management version 2
        Capabilities: [58] Debug port: BAR=1 offset=00a0
        Capabilities: [98] PCI Advanced Features
        Kernel driver in use: ehci_hcd
00:1b.0 Audio device [0403]: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller [8086:1c20] (rev 05)
        Flags: bus master, fast devsel, latency 0, IRQ 51
        Memory at f7f00000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Root Complex Integrated Endpoint, MSI 00
        Capabilities: [100] Virtual Channel
        Capabilities: [130] Root Complex Link
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd-hda-intel
00:1c.0 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 [8086:1c10] (rev b5) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 0000e000-0000efff
        Prefetchable memory behind bridge: 00000000f0000000-00000000f00fffff
        Capabilities: [40] Express Root Port (Slot+), MSI 00
        Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
        Capabilities: [90] Subsystem: ZOTAC International (MCO) Ltd. Device [19da:a206]
        Capabilities: [a0] Power Management version 2
        Kernel driver in use: pcieport
        Kernel modules: shpchp
00:1c.2 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 3 [8086:1c14] (rev b5) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        Memory behind bridge: f7e00000-f7efffff
00:1c.3 PCI bridge [0604]: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 [8086:1c16] (rev b5) (prog-if 00 [Normal decode])
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        Memory behind bridge: f7c00000-f7dfffff
00:1d.0 USB controller [0c03]: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 [8086:1c26] (rev 05) (prog-if 20 [EHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 23
        Memory at f7f06000 (32-bit, non-prefetchable) [size=1K]
00:1f.0 ISA bridge [0601]: Intel Corporation HM65 Express Chipset Family LPC Controller [8086:1c49] (rev 05)
        Kernel modules: iTCO_wdt
00:1f.2 IDE interface [0101]: Intel Corporation 6 Series/C200 Series Chipset Family 4 port SATA IDE Controller [8086:1c01] (rev 05) (prog-if 8f [Master SecP SecO PriP PriO])
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 19
        I/O ports at f110 [size=8]
        I/O ports at f100 [size=4]
        I/O ports at f0f0 [size=8]
        I/O ports at f0e0 [size=4]
        I/O ports at f0d0 [size=16]
        I/O ports at f0c0 [size=16]
        Capabilities: [70] Power Management version 3
        Capabilities: [b0] PCI Advanced Features
        Kernel driver in use: ata_piix
00:1f.3 SMBus [0c05]: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller [8086:1c22] (rev 05)
        Flags: medium devsel, IRQ 3
        Memory at f7f05000 (64-bit, non-prefetchable) [size=256]
        I/O ports at f040 [size=32]
        Kernel modules: i2c-i801
00:1f.5 IDE interface [0101]: Intel Corporation 6 Series/C200 Series Chipset Family 2 port SATA IDE Controller [8086:1c09] (rev 05) (prog-if 85 [Master SecO PriO])
        I/O ports at f0b0 [size=8]
        I/O ports at f0a0 [size=4]
        I/O ports at f090 [size=8]
        I/O ports at f080 [size=4]
        I/O ports at f070 [size=16]
        I/O ports at f060 [size=16]
01:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 06)
        Subsystem: Realtek Semiconductor Co., Ltd. Device [10ec:0123]
        Flags: bus master, fast devsel, latency 0, IRQ 48
        I/O ports at e000 [size=256]
        Memory at f0004000 (64-bit, prefetchable) [size=4K]
        Memory at f0000000 (64-bit, prefetchable) [size=16K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 01
        Capabilities: [b0] MSI-X: Enable- Count=4 Masked-
        Capabilities: [d0] Vital Product Data
        Capabilities: [160] Device Serial Number 30-12-00-00-68-4c-e0-00
        Kernel driver in use: r8169
        Kernel modules: r8169
02:00.0 USB controller [0c03]: NEC Corporation uPD720200 USB 3.0 Host Controller [1033:0194] (rev 04) (prog-if 30 [XHCI])
        Subsystem: ZOTAC International (MCO) Ltd. Device [19da:0194]
        Memory at f7e00000 (64-bit, non-prefetchable) [size=8K]
        Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+
        Capabilities: [90] MSI-X: Enable+ Count=8 Masked-
        Capabilities: [a0] Express Endpoint, MSI 00
        Capabilities: [140] Device Serial Number ff-ff-ff-ff-ff-ff-ff-ff
        Capabilities: [150] Latency Tolerance Reporting
        Kernel driver in use: xhci_hcd
03:00.0 Network controller [0280]: Ralink corp. Device [1814:3290]
        Subsystem: AzureWave Device [1a3b:2b87]
        Flags: bus master, fast devsel, latency 0, IRQ 19
        Memory at f7d40000 (32-bit, non-prefetchable) [size=64K]
        Memory at f7d30000 (32-bit, non-prefetchable) [size=64K]
        Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Capabilities: [70] Express Endpoint, MSI 00
        Capabilities: [140] Device Serial Number 00-00-bf-a5-a9-c9-db-94
        Kernel driver in use: rt2860
        Kernel modules: rt3290sta
03:00.1 Bluetooth [0d11]: Ralink corp. Device [1814:3298]
        Subsystem: AzureWave Device [1a3b:2987]
        Flags: bus master, fast devsel, latency 0, IRQ 10
        Memory at f7d20000 (32-bit, non-prefetchable) [size=64K]
        Memory at f7d10000 (32-bit, non-prefetchable) [size=64K]
        Memory at f7c00000 (32-bit, non-prefetchable) [size=1M]
        Expansion ROM at f7d00000 [disabled] [size=64K]
        Capabilities: [140] Device Serial Number 00-00-9e-a3-a9-c9-db-94
Can you run:
sudo updatedb
then post the output from:
dmesg | grep 3290
locate 3290
dmesg log: only 50 lines, the rest is the same and repeats TSSI line many times
rad@rad-ZBOX-ID82:~$ dmesg | grep 3290 | head -50
[    0.659933] pci 0000:03:00.0: [1814:3290] type 0 class 0x000280
[   18.032367] rt3290sta: module license 'unspecified' taints kernel.
[   18.035215] device_id =0x3290
[   19.069127] MACVersion=0x32900003
[   19.328182] MACVersion=0x32900003
[   19.795822] /home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/../../common/cmm_asic.c:2608 assert KeyIdx < 4failed
[   19.795831] /home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/../../common/cmm_asic.c:2608 assert KeyIdx < 4failed
[   27.123796] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   31.119498] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   35.117012] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   39.115656] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   47.113836] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   51.111444] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   55.109127] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   59.107685] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   63.104268] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   67.101950] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   79.095788] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   83.092292] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   87.089932] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   91.087583] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   95.085153] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   99.083774] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  115.081274] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  119.079823] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  123.076409] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  127.074113] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  131.071643] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  135.069250] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  139.067970] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  167.054125] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  171.051743] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  175.049416] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  179.047965] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  183.044558] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  187.042243] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  227.026225] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  231.023866] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  235.021513] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  239.020067] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  243.016668] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  247.014355] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  286.994353] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  290.991991] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  294.989643] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  298.988211] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  302.984806] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  306.982491] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  346.962477] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  350.960112] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
locate log:
rad@rad-ZBOX-ID82:/$ locate 3290
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508.tar.gz
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/Makefile
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/README_STA_pci
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/RT2860STA.dat
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/RT2860STACard.dat
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/iwpriv_usage.txt
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta_ate_iwpriv_usage.txt
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/tools
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/.rt30xx.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/.rt3290.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/.rtmp_chip.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rt28xx.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rt30xx.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rt30xx.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rt3290.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rt3290.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rtmp_chip.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/chips/rtmp_chip.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.action.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.ba_action.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_aes.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_asic.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_cfg.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_cmd.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_data.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_data_pci.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_info.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_mac_pci.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_profile.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_radar.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_sanity.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_sync.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_tkip.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_wep.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.cmm_wpa.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.crypt_aes.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.crypt_arc4.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.crypt_hmac.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.crypt_md5.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.crypt_sha2.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.ee_efuse.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.ee_prom.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.eeprom.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.frq_cal.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.mlme.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.ps.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rt_channel.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rt_led.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rt_os_util.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rt_rf.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rtmp_init.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rtmp_init_inf.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rtmp_mcu.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.rtmp_timer.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.spectrum.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/.uapsd.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/action.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/action.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ba_action.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ba_action.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/client_wds.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_aes.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_aes.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_asic.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_asic.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_cfg.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_cfg.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_cmd.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_cmd.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_cs.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_data.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_data.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_data_pci.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_data_pci.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_info.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_info.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_mac_pci.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_mac_pci.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_profile.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_profile.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_radar.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_radar.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_sanity.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_sanity.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_sync.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_sync.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_tkip.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_tkip.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_video.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_wep.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_wep.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_wpa.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/cmm_wpa.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_aes.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_aes.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_arc4.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_arc4.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_hmac.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_hmac.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_md5.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_md5.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_sha2.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/crypt_sha2.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ee_efuse.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ee_efuse.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ee_prom.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ee_prom.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/eeprom.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/eeprom.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/frq_cal.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/frq_cal.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/frq_cal_ori.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/misc.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/mlme.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/mlme.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/netif_block.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ps.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/ps.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt2860.bin_ori
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt2860_ori.bin
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt3290.bin
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_channel.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_channel.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_led.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_led.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_os_util.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_os_util.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_rf.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rt_rf.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_init.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_init.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_init_inf.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_init_inf.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_mcu.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_mcu.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_timer.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/rtmp_timer.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/spectrum.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/spectrum.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/uapsd.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/common/uapsd.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/action.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/ags.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/ap.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/ap_diversity.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/br_ftph.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/cfg80211.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/cfg80211extr.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chlist.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/client_wds.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/client_wds_cmm.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/crypt_aes.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/crypt_arc4.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/crypt_hmac.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/crypt_md5.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/crypt_sha2.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/cs.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/dfs.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/dot11i_wpa.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/drs_extr.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/eeprom.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/firmware.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/frq_cal.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/iface
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/link_list.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/misc.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/misc_cmm.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/mlme.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/netif_block.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/oid.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/os
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/radar.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rt_config.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rt_led.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rt_os_net.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rt_os_util.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rt_txbf.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_chip.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_cmd.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_comm.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_def.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_dot11.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_iface.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_mcu.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_os.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_osabl.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_timer.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/rtmp_type.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/spectrum.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/spectrum_def.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/sta_cfg.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/uapsd.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/video.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/vr_ikans.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/vrut_ubm.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/wpa.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/wpa_cmm.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/wsc.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/chip_id.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/mac_pci.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/rt28xx.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/rt30xx.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/rt3290.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/rtmp_mac.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/chip/rtmp_phy.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/iface/iface_util.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/iface/rtmp_pci.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/os/rt_drv.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/os/rt_linux.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/os/rt_linux_cmm.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/include/os/rt_os.h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.pci_main_dev.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt3290sta.ko.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt3290sta.mod.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt3290sta.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt_linux.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt_main_dev.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt_pci_rbus.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt_profile.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt_rbus_pci_drv.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.rt_rbus_pci_util.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.sta_ioctl.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.tmp_versions
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Kconfig.ap.soc
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Kconfig.ap.usb
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Kconfig.sta.soc
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.4
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.4.netif
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.4.util
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.6
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.6.netif
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.6.netif~
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.6.util
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.ap.soc
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.ap.usb
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.clean
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.libautoprovision.6
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Makefile.sta.soc
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/Module.symvers
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/br_ftph.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/cfg80211.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/cfg80211drv.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/config.mk
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/config.mk~
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/inf_ppa.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/modules.order
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/pci_main_dev.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/pci_main_dev.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt3290sta.ko
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt3290sta.mod.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt3290sta.mod.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt3290sta.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_linux.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_linux.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_linux_symb.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_main_dev.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_main_dev.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_pci_rbus.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_pci_rbus.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_proc.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_profile.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_profile.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_rbus_pci_drv.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_rbus_pci_drv.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_rbus_pci_util.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_rbus_pci_util.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/rt_symb.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/sta_ioctl.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/sta_ioctl.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/vr_bdlt.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/vr_ikans.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/.tmp_versions/rt3290sta.mod
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/.alg_ags.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/.alg_legacy.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/.ra_ctrl.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/alg_ags.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/alg_ags.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/alg_grp.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/alg_legacy.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/alg_legacy.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/ra_ctrl.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/rate_ctrl/ra_ctrl.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.assoc.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.auth.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.auth_rsp.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.connect.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.rtmp_data.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.sanity.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.sta_cfg.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.sync.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/.wpa.o.cmd
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/assoc.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/assoc.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/auth.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/auth.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/auth_rsp.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/auth_rsp.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/connect.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/connect.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/dls.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/rtmp_ckipmic.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/rtmp_data.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/rtmp_data.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/sanity.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/sanity.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/sta_cfg.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/sta_cfg.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/sync.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/sync.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/wpa.c
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/sta/wpa.o
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/tools/Makefile
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/tools/bin2h
/home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/tools/bin2h.c
/lib/modules/3.2.0-35-generic/kernel/drivers/net/wireless/rt3290sta.ko
/lib/modules/3.2.0-36-generic/kernel/drivers/net/wireless/rt3290sta.ko
Can you post the output from:
cat /etc/*-release
uname -a
rad@rad-ZBOX-ID82:~$ cat /etc/*-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
DISTRIB_CODENAME=precise
DISTRIB_DESCRIPTION="Ubuntu 12.04.1 LTS"
NAME="Ubuntu"
VERSION="12.04.1 LTS, Precise Pangolin"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu precise (12.04.1 LTS)"
VERSION_ID="12.04"
rad@rad-ZBOX-ID82:~$ uname -a
Linux rad-ZBOX-ID82 3.2.0-36-generic #57-Ubuntu SMP Tue Jan 8 21:44:52 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
OK, first of all this shouldn’t be happening in 12.04 … you seem to be getting the same errors as 12.10 users are getting … which is odd, maybe they’ve updated something in 12.04 that’s broken these drivers, but I’m a bit baffled by those lines from dmesg that point to your home folder.
Can you run:
sudo modprobe -r rt3290sta
sudo modprobe rt3290sta
dmesg | tail -n 50
and post the output.
dpkg -l | grep linux-image
rad@rad-ZBOX-ID82:~$ dmesg | tail -n 100
[   19.488917] MCS Set = ff 00 00 00 01
[   19.488923] <==== rt28xx_init, Status=0
[   19.488981] 0x1300 = 00064300
[   19.488983] RTMPrt3xSetPCIePowerLinkCtrl.===> 1e
[   19.529673] HDMI status: Codec=3 Pin=6 Presence_Detect=0 ELD_Valid=0
[   19.529735] HDMI status: Codec=3 Pin=7 Presence_Detect=0 ELD_Valid=0
[   19.529823] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[   19.529936] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[   19.530032] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[   19.530123] input: HDA Intel PCH Line-Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   19.539633] CacheVal-OnOff:0, bPCIclkOff:1, WlanFunCtrl:0xff000133
[   19.539639] ==> RTMPWlan 0, bPCIclkOff = 1, pAd->WlanFunCtrl.word = 0xff000123
[   19.539641] Set INT_MASK_CSR = 0
[   19.539648] ==> RTMPWlan 0, bPCIclkOff = 1, WlanFunCtrl.word = 0xff000120
[   19.539652] <== RTMPWlan 0  bPCIclkOff = 1 pAd->WlanFunCtrl.word = 0xff000120
[   19.546708] CacheVal-OnOff:0, bPCIclkOff:1, WlanFunCtrl:0xff000120
[   19.546718] ==> RTMPWlan 0, bPCIclkOff = 1, pAd->WlanFunCtrl.word = 0xff000120
[   19.546719] Set INT_MASK_CSR = 0
[   19.546750] ==> RTMPWlan 0, bPCIclkOff = 1, WlanFunCtrl.word = 0xff000120
[   19.546755] <== RTMPWlan 0  bPCIclkOff = 1 pAd->WlanFunCtrl.word = 0xff000120
[   19.551369] MACVersion=0x32900003
[   19.551373] CacheVal-OnOff:1, bPCIclkOff:0, WlanFunCtrl:0xff000120
[   19.551382] ==> RTMPWlan 1, bPCIclkOff = 0, pAd->WlanFunCtrl.word = 0xff000120
[   19.551384] ==> RTMPWlan 1, bPCIclkOff = 0, WlanFunCtrl.word = 0xff000121
[   19.551700] <== RTMPWlan 1  bPCIclkOff = 0 pAd->WlanFunCtrl.word = 0xff000123
[   19.553044] RX DESC ffff880036c44000  size = 2048
[   19.553241] RTMP_TimerListAdd: add timer obj ffffc90006d4ed60!
[   19.553243] RTMP_TimerListAdd: add timer obj ffffc90006d4edd0!
[   19.553245] RTMP_TimerListAdd: add timer obj ffffc90006d4ee40!
[   19.553247] RTMP_TimerListAdd: add timer obj ffffc90006d4ecf0!
[   19.553249] RTMP_TimerListAdd: add timer obj ffffc90006d4eba0!
[   19.553251] RTMP_TimerListAdd: add timer obj ffffc90006d4ec10!
[   19.553253] RTMP_TimerListAdd: add timer obj ffffc90006d18d20!
[   19.553255] RTMP_TimerListAdd: add timer obj ffffc90006d18d90!
[   19.553257] RTMP_TimerListAdd: add timer obj ffffc90006d18c38!
[   19.553258] RTMP_TimerListAdd: add timer obj ffffc90006d07b30!
[   19.553260] RTMP_TimerListAdd: add timer obj ffffc90006d07ba8!
[   19.553262] RTMP_TimerListAdd: add timer obj ffffc90006d18b58!
[   19.553264] RTMP_TimerListAdd: add timer obj ffffc90006d18e20!
[   19.555220] BBP_R105: BBPR105.field.EnableSIGRemodulation = 1, BBPR105.field.MLDFor2Stream = 0
[   19.556174] Key1Str is Invalid key length(0) or Type(0)
[   19.556185] Key2Str is Invalid key length(0) or Type(0)
[   19.556197] Key3Str is Invalid key length(0) or Type(0)
[   19.556208] Key4Str is Invalid key length(0) or Type(0)
[   19.556423] 1. Phy Mode = 9
[   19.556424] 2. Phy Mode = 9
[   19.556431] NVM is Efuse and its size =1e[1e0-1fd]
[   19.557721] 3. Phy Mode = 9
[   19.557758] \x1b[mAntCfgInit: primary/secondary ant 0/1
[   19.557759] \x1b[mCacheVal-OnOff:1, bPCIclkOff:0, WlanFunCtrl:0xff000123
[   19.591003] ==> RTMPWlan 1, bPCIclkOff = 0, pAd->WlanFunCtrl.word = 0xff000133
[   19.591006] <== RTMPWlan bPCIclkOff = 0, Exit because WLAN EN is already ON
[   19.594113] RTMPSetPhyMode: channel is out of range, use first channel=1
[   19.594141] MCS Set = ff 00 00 00 01
[   19.594147] <==== rt28xx_init, Status=0
[   19.594206] 0x1300 = 00064300
[   19.594208] RTMPrt3xSetPCIePowerLinkCtrl.===> 1e
[   19.596487] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[   19.970286] type=1400 audit(1358777340.851:7): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=1114 comm="apparmor_parser"
[   19.971217] type=1400 audit(1358777340.851:8): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=1115 comm="apparmor_parser"
[   19.971719] type=1400 audit(1358777340.855:9): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1115 comm="apparmor_parser"
[   19.971993] type=1400 audit(1358777340.855:10): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=1115 comm="apparmor_parser"
[   19.973071] type=1400 audit(1358777340.855:11): apparmor="STATUS" operation="profile_load" name="/usr/lib/telepathy/mission-control-5" pid=1118 comm="apparmor_parser"
[   19.979313] /home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/../../common/cmm_asic.c:2608 assert KeyIdx < 4failed
[   19.979321] /home/rad/ralink/DPO_RT3290_LinuxSTA_V2600_20120508/os/linux/../../common/cmm_asic.c:2608 assert KeyIdx < 4failed
[   20.544879] vboxdrv: Found 4 processor cores.
[   20.545206] vboxdrv: fAsync=0 offMin=0x1ac offMax=0x33a0
[   20.545253] vboxdrv: TSC mode is 'synchronous', kernel timer mode is 'normal'.
[   20.545255] vboxdrv: Successfully loaded version 4.1.12_Ubuntu (interface 0x00190000).
[   20.601026] vboxpci: IOMMU not found (not registered)
[   21.125599] init: plymouth-stop pre-start process (1528) terminated with status 1
[   21.663191] r8169 0000:01:00.0: eth0: link up
[   21.664315] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   24.440918] [UFW BLOCK] IN=eth0 OUT= MAC=00:01:2e:47:95:d3:00:12:0e:51:fd:a4:08:00 SRC=108.160.161.160 DST=10.0.8.82 LEN=231 TOS=0x00 PREC=0x00 TTL=44 ID=2915 DF PROTO=TCP SPT=80 DPT=33824 WINDOW=83 RES=0x00 ACK PSH URGP=0
[   27.447182] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   31.442863] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   32.669365] eth0: no IPv6 routers present
[   35.438408] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   37.642441] [UFW BLOCK] IN=eth0 OUT= MAC=00:01:2e:47:95:d3:00:12:0e:51:fd:a4:08:00 SRC=108.160.161.160 DST=10.0.8.82 LEN=231 TOS=0x00 PREC=0x00 TTL=44 ID=2916 DF PROTO=TCP SPT=80 DPT=33824 WINDOW=83 RES=0x00 ACK PSH URGP=0
[   39.434977] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   47.429230] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   51.424840] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   55.420499] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   59.417073] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   63.411667] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   64.048336] [UFW BLOCK] IN=eth0 OUT= MAC=00:01:2e:47:95:d3:00:12:0e:51:fd:a4:08:00 SRC=108.160.161.160 DST=10.0.8.82 LEN=231 TOS=0x00 PREC=0x00 TTL=44 ID=2917 DF PROTO=TCP SPT=80 DPT=33824 WINDOW=83 RES=0x00 ACK PSH URGP=0
[   67.407354] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   79.399190] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   83.397675] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   87.393285] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   91.389014] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   95.384552] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[   99.381177] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  115.366626] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  119.363219] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  123.357809] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  127.357487] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  131.353030] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  135.348641] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
[  167.313509] RT3290_AsicTxAlcGetAutoAgcOffset: Incorrect desired TSSI or current TSSI
rad@rad-ZBOX-ID82:~$ dpkg -l | grep linux-image
ii  linux-image-3.2.0-29-generic           3.2.0-29.46                             Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii  linux-image-3.2.0-32-generic           3.2.0-32.51                             Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii  linux-image-3.2.0-33-generic           3.2.0-33.52                             Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii  linux-image-3.2.0-34-generic           3.2.0-34.53                             Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii  linux-image-3.2.0-35-generic           3.2.0-35.55                             Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii  linux-image-3.2.0-36-generic           3.2.0-36.57                             Linux kernel image for version 3.2.0 on 64 bit x86 SMP
ii  linux-image-generic                    3.2.0.36.43                             Generic Linux kernel image
