Ralink wireless card does not work [SOLVED]
It works after reboot, thanks for help
Hi,
I follow the steps to upgrade linux kernel and copy firmware. At first it works but after reboot it fails. I cant get wlan0 up
xurde@worky:~$ iwlist scanning
wlan0 Failed to read scan data : Network is down
xurde@worky:~$ sudo ifconfig wlan0 up
SIOCSIFFLAGS: Error de entrada/salida
Anyone can help me? Thx
Which driver did you install ?
What is the output from:
sudo lshw -C network
iwconfig
rfkill list
I installed the kernel 3.7.2 and copy the rt3290.bin firmaware to /lib/firmware
xurde@worky:~$ sudo lshw -C network
  *-network DESACTIVADO
       descripción: Interfaz inalámbrica
       producto: Ralink corp.
       fabricante: Ralink corp.
       id físico: 0
       información del bus: pci@0000:01:00.0
       nombre lógico: wlan0
       versión: 00
       serie: a4:17:31:08:24:4b
       anchura: 32 bits
       reloj: 33MHz
       capacidades: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuración: broadcast=yes driver=rt2800pci latency=0 multicast=yes wireless=IEEE 802.11bgn
       recursos: irq:16 memoria:c2510000-c251ffff
  *-network
       descripción: Ethernet interface
       producto: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
       fabricante: Realtek Semiconductor Co., Ltd.
       id físico: 0
       información del bus: pci@0000:02:00.0
       nombre lógico: eth0
       versión: 05
       serie: 84:34:97:7a:29:12
       tamaño: 100Mbit/s
       capacidad: 100Mbit/s
       anchura: 64 bits
       reloj: 33MHz
       capacidades: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuración: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8105e-1.fw ip=192.168.0.33 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       recursos: irq:42 ioport:3000(size=256) memoria:c2404000-c2404fff memoria:c2400000-c2403fff
xurde@worky:~$ iwconfig
eth0      no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:off/any
          Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
          Retry  long limit:7   RTS thr:off   Fragment thr:off
          Power Management:off
xurde@worky:~$ rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
Sometimes after reboot it works but normally not.
Ok, I have a clue. If I reboot the wifi doesn’t work, buy if I shutdown and then boot, the wifi works fine.
Is this a laptop ?
If so, what is the make/model ?
What’s the output from:
lsmod | grep rt
lspci -vnn | grep -i net
Yes, it is a Laptop, Sleekbook HP Pavilion 14-b000ss http://h20386.www2.hp.com/SpainStore/Merch/Product.aspx?id=C0T87EA&opt=ABE&sel=PCNB
xurde@worky:~$ lsmod | grep rt
parport_pc             32866  0
rt2800pci              18754  0
rt2800lib              67481  1 rt2800pci
crc_ccitt              12707  1 rt2800lib
rt2x00pci              14578  1 rt2800pci
rt2x00lib              55503  3 rt2800pci,rt2800lib,rt2x00pci
mac80211              626881  3 rt2800lib,rt2x00pci,rt2x00lib
rtsx_pci_ms            13180  0
cfg80211              525244  2 rt2x00lib,mac80211
memstick               16605  1 rtsx_pci_ms
eeprom_93cx6           13344  1 rt2800pci
parport                46562  3 parport_pc,ppdev,lp
rtsx_pci_sdmmc         17800  0
rtsx_pci               28709  2 rtsx_pci_ms,rtsx_pci_sdmmc
xurde@worky:~$ lspci -vnn | grep -i net
01:00.0 Network controller [0280]: Ralink corp. Device [1814:3290]
02:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101E/RTL8102E PCI Express Fast Ethernet controller [10ec:8136] (rev 05)
That’s a weird problem … are you 100% sure it ALWAYS works if you shut down rather than reboot ?
Yes, paying attention at rebooting I’ve seen a message about disconnect IRQ16, I think it is any kind of hardware problem. Shutdown instead of reboot isn’t critic, i think I’ll leave it
The exact message may help … but if you’re happy to just shut down instead.
I wonder if disabling APIC would help ?
The error in reboot was
[    3.474662] irq 16: nobody cared (try booting with the "irqpoll" option)
[    3.474705] Pid: 0, comm: swapper/1 Not tainted 3.8.6-030806-generic #201304051406
[    3.474706] Call Trace:
[    3.474708]  <IRQ>  [<ffffffff810f0d5d>] __report_bad_irq+0x3d/0xe0
[    3.474720]  [<ffffffff810f1185>] note_interrupt+0x135/0x190
[    3.474724]  [<ffffffff810ee999>] handle_irq_event_percpu+0xa9/0x210
[    3.474727]  [<ffffffff810eeb4e>] handle_irq_event+0x4e/0x80
[    3.474730]  [<ffffffff810f1d64>] handle_fasteoi_irq+0x64/0x120
[    3.474735]  [<ffffffff81016702>] handle_irq+0x22/0x40
[    3.474739]  [<ffffffff816f78ea>] do_IRQ+0x5a/0xe0
[    3.474743]  [<ffffffff816ed36d>] common_interrupt+0x6d/0x6d
[    3.474744]  <EOI>  [<ffffffff81585ad3>] ? cpuidle_wrap_enter+0x53/0xa0
[    3.474752]  [<ffffffff81585ac9>] ? cpuidle_wrap_enter+0x49/0xa0
[    3.474755]  [<ffffffff81585b30>] cpuidle_enter_tk+0x10/0x20
[    3.474758]  [<ffffffff815856ef>] cpuidle_idle_call+0xaf/0x2b0
[    3.474763]  [<ffffffff8101daef>] cpu_idle+0xcf/0x120
[    3.474767]  [<ffffffff816cac69>] start_secondary+0xc3/0xc5
[    3.474769] handlers:
[    3.474786] [<ffffffff81508a30>] usb_hcd_irq
[    3.474813] Disabling IRQ #16
do you know how to add
irqpoll
as a kernel boot parameter ?
If that doesn’t work, try
pci=routeirq
instead.
If neither help … what’s the output from:
cat /proc/interrupts
Hello,
I’ve really found your post useful but I think I’m over my head a little on putting the pieces together. I am trying to run Ubuntu 12.04 on an HP Envy i bought from Woot.com (http://tech.woot.com/offers/hp-envy-six-core-desktop-w-10gb-ram). I worked through this post:
  1. got card recognized and on the network, but it froze when I used it
  2. using the instructions on the 3/4 page and now I’ve got a working network card and no freezing
    But… I have really bad packet loss %50+.
    I’m not sure if I have done a bad combination of steps (it really is just a series of steps, because I dont quite understand all the pieces… like rt2800pci vs rt3290sta) or if I have another issue, but I was hoping I could get some help diagnosing or finding the where to look next.
Any input would be much appreciated. I’ve snipped as much information I could think to include.
comp:~$ tail /etc/modprobe.d/blacklist.conf -n3
#Wireless drivers conflicting with rt3562sta
blacklist rt2800pci
blacklist rt2x00pci
comp:~$ tail /etc/modules -n3
rtc
rt3290
rt3290sta
comp:~$ uname -a
Linux sixthsin 3.7.2-030702-generic #201301111424 SMP Fri Jan 11 19:25:11 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
comp:~$ lsmod | grep rt
rt2800pci              18755  0
rt2800lib              67474  1 rt2800pci
crc_ccitt              12708  1 rt2800lib
rt2x00pci              14579  1 rt2800pci
rt2x00lib              55504  3 rt2800pci,rt2800lib,rt2x00pci
mac80211              569091  3 rt2800lib,rt2x00pci,rt2x00lib
cfg80211              208484  2 rt2x00lib,mac80211
eeprom_93cx6           13345  1 rt2800pci
parport_pc             32867  0
parport                46563  3 parport_pc,ppdev,lp
comp:/etc/modprobe.d$ sudo lshw -C network
  *-network
       product: Ralink corp.
       vendor: Ralink corp.
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: wlan0
       version: 00
       serial: 68:94:23:7e:d9:e7
       width: 32 bits
       configuration: broadcast=yes driver=rt2800pci latency=0 multicast=yes wireless=IEEE 802.11bgn
       resources: irq:22 memory:fe810000-fe81ffff
  *-network
       physical id: 0
       bus info: pci@0000:07:00.0
       logical name: eth0
       version: 06
       serial: 90:2b:34:e8:cb:94
       capacity: 1Gbit/s
       width: 64 bits
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiatio n
       configuration: autonegotiatio n=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8168e-2.fw ip=192.168.1.146 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:80 ioport:d000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
comp:~$ iwconfig
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
comp:~$ lspci -vnn | grep -i net
06:00.0 Network controller [0280]: Ralink corp. Device [1814:3290]
07:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168B PCI Express Gigabit Ethernet controller [10ec:8168] (rev 06)
... full entry ...
    Subsystem: Hewlett-Packard Company Device [103c:18ec]
    Flags: bus master, fast devsel, latency 0, IRQ 22
    Memory at fe810000 (32-bit, non-prefetchable) [size=64K]
    Capabilities: [40] Power Management version 3
    Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
    Capabilities: [70] Express Endpoint, MSI 00
    Capabilities: [100] Advanced Error Reporting
    Capabilities: [140] Device Serial Number 00-00-e7-d9-7e-23-94-68
    Kernel driver in use: rt2800pci
    Kernel modules: rt2800pci
06:00.1 Bluetooth [0d11]: Ralink corp. Device [1814:3298]
    Flags: fast devsel, IRQ 4
    Memory at fe800000 (32-bit, non-prefetchable) [disabled] [size=64K]
    Capabilities: [140] Device Serial Number 00-00-e8-d9-7e-23-94-68
comp:~$ dpkg -l | grep linux-image
ii  linux-image-3.5.0-23-generic                 3.5.0-23.35~precise1                             Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-3.5.0-34-generic                 3.5.0-34.55~precise1                             Linux kernel image for version 3.5.0 on 64 bit x86 SMP
ii  linux-image-3.7.2-030702-generic             3.7.2-030702.201301111424                        Linux kernel image for version 3.7.2 on 64 bit x86 SMP
ii  linux-image-extra-3.7.2-030702-generic       3.7.2-030702.201301111424                        Linux kernel image for version 3.7.2 on 64 bit x86 SMP
ii  linux-image-generic-lts-quantal              3.5.0.34.41                                      Generic Linux kernel image
Hi tatagatha and welcome to the forum :slight_smile:
I gather you need the rt3290sta drivers for your card, but I don’t know if you’ve already installed them or not … can you send the output from:
modinfo rt3290sta
and we’ll go from there.
ERROR: modinfo: could not find module rt3290sta
How could I have a working network connection with lots of dropped packets if I didn’t have the driver at all? I think there is part of this picture I am missing. Are there two pieces to the drivers? Or two drivers for the same card and one is better than the other?
Also… Thanks!
There are 2 drivers available for your card
a) rt2800pci which is the open source generic driver built into the Linux kernel … works perfectly well with most Ralink PCI adapters, but not all.
b) rt3290sta the proprietary drivers which cannot be included in the kernel … so you’ll need to download and compile it.
I’ll post instructions in a bit.
You’ll need to install a couple of things before compiling, so are you able to connect your PC to your router with an ethernet cable … so you have a stable internet connection whilst we sort out the wireless ?
And just to be 100% sure … you’re using Ubuntu 12.04 64bit right ?
Ah… ok. I think I understand now. The black list is what prevents one driver from being loaded so that the other can be used…
Yes, I’m able to use a wired connection.
Yes, I’m using 12.04 64 bit.
OK, I’ll post the instructions anyway, but from what I gather these instructions won’t work for the 3.7 kernel … is there any particular reason you’re not running 12.04’s default 3.2 kernel ?
WARNING - DO NOT attempt these instructions on anything above the 3.2 kernel, they will fail to compile and/or won’t work
Open a terminal and run:
sudo apt-get update && sudo apt-get install build-essential linux-headers-generic
wait for that command to finish and leave you back at an $ prompt, then run:
cd ~
then:
wget https://dl.dropboxusercontent.com/u/11876059/DPO_RT3290_LinuxSTA_V2600_20120508.tar.gz
then:
tar -xvf DPO_RT3290_LinuxSTA_V2600_20120508.tar.gz
then:
cd ~/DPO_RT3290_LinuxSTA_V2600_20120508
then:
sudo su
enter your password when prompted and hit enter (the prompt should change from $ to #), then:
make
then when that finishes:
make install
then:
exit
then:
sudo modprobe -r rt2800pci
sudo modprobe rt3290sta
Does your wireless still work ?
If so, reboot … then post the output from:
so we can check the rt3290sta drivers are still being used.
I ended up using the 3.7 kernel when following instructions you gave ‘powery’ earlier in this thread.
I have followed some steps that as I can tell are identical to the ones you gave me (except the extra step of adding rt3290sta to the modlues list) and while I was able to get connected to the wireless network, the moment i tried to use the interface ubuntu froze. That is when I found this post and an issue very similar to ‘powery’ : Ubuntu froze and the only clue was about “Incorrect desired TSSI or current TSSI”. I dont know if that give a clearer view of how i got to the state I’m in. I can always do a fresh install since there is nothing i care about on this machine yet.
I’m away from that computer right now, but I will try later tonight. I can also switch kernals to the 3.2 ( I use the grub bootloader to make this selection?)
Thanks!
