Rawtherapee installation
I have installed Rawtherapee on my laptop (Ubuntu 10.10) no but, can’t seem to install it on 10.04, any ideas?
There is no rawtherapee package in the Lucid repos, but it IS available online.
Maverick’s version 3.0, according to the Rawtherapee website isn’t stable yet… so they only have version 2.4.1 available for download.
(well in truth there v3.0 are branch builds available, but I’d stear clear for now)
32bit version:
http://www.rawtherapee.com/rawtherapee241.tgz
64bit version:
http://www.rawtherapee.com/rawtherapee241_64.tgz
Rawtherapee Homepage:
http://www.rawtherapee.com/?
To install… you don’t have to, it’s standalone… just unpack, and double-click the “rt” executable to run.
OR if you actually want it INSTALLED on a 10.04 system… GetDeb, have packaged them as .deb packages which should sort out dependencies for you.
32bit .deb direct package download (from GetDeb):
http://archive.getdeb.net/ubuntu/pool/apps/r/rawtherapee/rawtherapee_2.4.1-1~getdeb1_i386.deb
64bit .deb direct package download (from GetDeb):
http://archive.getdeb.net/ubuntu/pool/apps/r/rawtherapee/rawtherapee_2.4.1-1~getdeb1_amd64.deb
Just double-click the .deb to install.
OR, you could add the RawTherapee PPA and install rawtherapee 3.0 (alpha) by following these instructions:
Open a terminal and enter these 3 commands:
sudo add-apt-repository ppa:rawtherapee/ppa
sudo apt-get install rawtherapee
This RawTherapee PPA contains versions for Lucid and Karmic.
Future readers might also want to take a look at rawstudio, which is available in the Ubuntu repos. ?
sudo apt-get install rawstudio
You’ll then find it in at Applications>Graphics>Rawstudio
Website/Screenshots here, in case you want to take a look:
http://rawstudio.org/screenshots.php
