Re: moonlight PROBLEM SOLVED
Is it safe to remove moonlight@novell.com from my UBUNTU setup ?
take care
Don W
You’ll have to explain that a bit … remove it from where ?
Are you talking about the Moonlight browser extension ? … if so YES.
If you’re using Firefox, in Firefox just go to Tools>Add-ons>Extensions and click the “Remove” button next to “Novell Moonlight 3.99.0.3” (or whatever version you have intalled).
Thanks Mark. That’s what I needed.
I added the extension per the book ‘Ubuntu for non geeks’ but the moonlight extension didn’t work properly.
I may try later using the Synaptic package manager, but I will wait and see.
take care
Don W
It works OK on “some” silverlight stuff if you install it from here:
http://www.go-mono.com/moonlight/download.aspx
There’s a test for Silverlight 2.0 here:
http://bubblemark.com/silverlight2.html
and for Silverlight 3.0 here:
http://bubblemark.com/sl3/TestPage.html
if you see an animation it’s working, if you see a button to install Microsoft Silverlight it isn’t.
But as I said Moonlight won’t work with ALL Silverlight content … not to mention that Siverlight is a dying format, if you Google it you’ll see that even Microsoft appear to be dropping it in favour of HTML5 :slight_smile:
In reality, Silverlight was stillborn to begin with … Microsoft tried to kick life into it, but appear to have given up.
Thanks Mark,
It has been erased and I am happy.
take care
Don W
