Returns to options of Create a document & Create a folder
in one windows by right click in the mouse.
in linux lubuntu 15.10.
How exactly do that?
So you’re saying if you right-click on an empty space in a folder you don’t get the “Create New Folder” and “Create New Document” options ?
Have you ever had these options ?
What happens if you right-click on an empty space on the desktop ?
“Have you ever had these options ?”
yes
“What happens if you right-click on an empty space on the desktop ?”
I get another menu of
Shortcuts
Applications
system
Run:
leafpad ~/.config/pcmanfm/lubuntu/pcmanfm.conf
look for an entry:-
show_wm_menu=1
and change it to
show_wm_menu=0
SAVE the file … then log off and on again (or reboot).
Another method…
open a terminal and run:
pcmanfm --desktop-pref
select the “Advanced” tab … and untick “Show Menus”
