Script that creates files/folders on samba drive fails
Bonjour,
I have modified a very simplistic script I was using to create folder/file backups as ZIP files onto a local drive too using the address of a Samba drive:
/run/user/1000/gvfs/smb-share:server=filehub,share=filehub_backups/Me/080317
Which is a share on a Windows 7 Professional machine.
However, if I go to that location in the Terminal I can create files/folders no issue. If I run the script every command returns “permission denied”.
Steps taken:
  • made sure script had execute permissions (tried 0750 and 0777)
  • always ran script using SUDO
  • checked smb.conf had RW permissions
  • created test script with same permissions that just accessed the Samba folder using CD (same error message)
At the moment I am at a loss as to how in Terminal using SUDO I can read/write but using a script run in Terminal as SUDO it just returns “permission denied”
Here is a bit of the script:
VARFOLDER=$(date +%d%m%y)
mkdir /run/user/1000/gvfs/smb-share:server=filehub,share=filehub_backups/Me/$VARFOLDER
If I copy that and replace $VARFOLDER with anything else and paste it into Terminal it works, but running the script with SUDO returns “permission denied” - ??
You could try (replace script.sh with your script):
sudo bash script.sh
that is exactly what I am doing but every line returns: “permission denied”
if I type the same commands directly into the Terminal it works -??
Are you using “sudo” in the script ?
what I mean is, if script.sh contains say
#!/bin/bash
nemo /
even if you run that script with
sudo ./script.sh
nemo will still open as a regular user
if on the other hand script.sh reads
#!/bin/bash
sudo nemo /
and you run it with
sudo ./script.sh
nemo will open with elevated privileges.
script.sh must also be set as exectutable
chmod +x script.sh
Done that!
The script has execute rights,
Changed the script to this:
#mkdir /run/user/1000/gvfs/smb-share:server=filehub,share=filehub_backups/Me/$VARFOLDER
sudo mkdir /run/user/1000/gvfs/smb-share:server=filehub,share=filehub_backups/Me/$VARFOLDER
exit
Ran thus:
roger@roger-HP-ProDesk-600-G2-SFF:~$ sudo /media/roger/Data/Scripts/CreateZIPBackups.sh
mkdir: cannot create directory ‘/run/user/1000/gvfs/smb-share:server=filehub,share=filehub_backups/Me/130317’: Permission denied
Same result!
I can create the folder directly using the same code in the same Terminal session without having to use SUDO - no issues?
It is as though Terminal has more disk access rights than a script run in the [i]same[/i ]Terminal with SUDO?? (I am system admin incidentally).
I suspect it has something to do with Samba. The share has RW access yet despite the executing attribute of the script and running/filling it with SUDO it seems Ubuntu gives direct Terminal commands read/write access but not scripts??
What’s the output from:
ls -l /run/user/1000
I’m going to guess that only roger has write permission for the
directory.
So the script needs to be run as roger, or the directory permissions changed as it’s mounted
Output:
-rw-rw-r-- 1 roger roger 60 Mar 15 07:05 dbus-session
drwx------ 2 roger roger 60 Mar 15 15:52 dconf
dr-x------ 3 roger roger 0 Mar 15 07:05 gvfs
drwx------ 2 roger roger 40 Mar 15 10:18 gvfs-burn
drwx------ 2 roger roger 100 Mar 15 07:05 keyring
drwx------ 2 roger roger 80 Mar 15 10:24 ksocket-roger
drwx------ 2 roger roger 80 Mar 15 07:05 pulse
drwx------ 4 roger roger 100 Mar 15 08:28 speech-dispatcher
drwxr-xr-x 2 roger roger 80 Mar 15 07:05 systemd
drwx------ 2 roger roger 40 Mar 15 07:05 unity
drwx------ 3 roger roger 60 Mar 15 07:05 upstart
-rw-r–r-- 1 roger roger 5 Mar 15 07:05 upstart-dbus-bridge.1644.pid
-rw-r–r-- 1 roger roger 5 Mar 15 07:05 upstart-file-bridge.1644.pid
-rw-r–r-- 1 roger roger 5 Mar 15 07:05 upstart-udev-bridge.1644.pid
Luckily there is only user on this machine :slight_smile:
well nobody other than roger has permission to read/write/execute the gvfs folder … so your script must be run as roger, not root.
roger is also a member of root.
Still does not explain why if I redirect the script to create the folder/files on any local drive it works, but not Samba shares…
