Setting up a printer in OOo4kids (Open Office for kids) (SOLVED)
Hi Guys
I’ve installed OOo4kids on my Grand-Daughters PC which is and Office suite based on Open Office but I can’t connect to the printer I’m only offered “Generic Printer & ”.
The program comes with a separate printer administration program with an add printer wizard but my printer model isn’t listed, I have an option to “Import” and when I select that it asks for a driver, I have a .ppd file for the printer located an “Downloads” but when I navigate there it doesn’t show it so I assume it must be the wrong file type
Have you tried bunging the PPD somewhere else, such as your home directory ?
I’m guessing this is based on a quite early version of OOo
I would have expected it to have just “known” about printers already added to CUPS, and not have needed them adding again through spadmin anyway.
I tried that but it made no difference
It has a separate admin application for setting up the printer probably because it’s a childrens program (Gcompris is the same)
Anyway I downloaded the universal driver from the Samsung site and extracted the zip file in Downloads and I can navigate to there it then seems to find the driver and adds the printer to the list of printers, so I can highlight the printer and click next on the next screen it’s asking me to enter “a command line appropriate for the device”
I don’t have a clue what that means
Here’s what I mean…
Do you have a PC with LibreOffice on it ? … if so run:
/usr/lib/libreoffice/program/spadmin
am I right in thinking that’s the same dialog window ?
LibreOffice does NOT require you to add printers that way as it should pick up the CUPS ones.
Anyway, I think it wants a command like:-
lp -d
lpstat -p -d
should list available destinations (printers)
Source:
http://www.openoffice.org/docs/setup_guide/appendix.html
am I right in thinking that's the same dialog window ?
No it’s a different window
chloe@Linux3 ~ $ lpstat -p -d
printer Samsung-CLP-320 is idle.  enabled since Sat 08 Nov 2014 13:49:08 GMT
no system default destination
chloe@Linux3 ~ $
Could it be there’s no destination found due to this being a network printer ?
Here’s a video showing the procedure maybe that will help explain it better
http://videobin.org/+89w/b37.html
Many thanks
Did you try
lp -d Samsung-CLP-320
as the command ?
Unfortunately that made no difference, when I try to print a document the printer dialogue box flashes up for a millisecond saying “preparing to print” but nothing is printed
Here is where I’ve downloaded the driver I selected the Linux version it’s the only option, I downloaded it to Documents and extracted it and when I run the printer wizard I’m navigating to the extracted folder
Many thanks
try
lpr -P Samsung-CLP-320
Sorted :slight_smile:
That got it working
Many thanks (I don’t know what you’d do without me ) :slight_smile:
No worries :slight_smile:
