shell script question
Hello, I am no shell script expert but have been dabbling for some time.
I have a routine that I user for killing selected tasks:-
for i in `ps aux|grep  "vlc" |grep -v grep | awk '{print $1}' ` ; do
          kill -9 $i
          done
On my arm linux machine (Nokia N900)
would typically return:-
19716 user     81648 S    /opt/VideoLAN/bin/vlc -I dummy --volume 120 http://name:password@localhost:9981/stream/channelid/60
Executing the kill code would kill task 19716 successfully.
If I modify the code in any way to be more selective in killing my vlc task, something like:-
for i in `ps aux|grep  "vlc -I dummy --volume 120 http://name:password@localhost:9981/stream/channelid" |grep -v grep | awk '{print $1}' ` ; do
          kill -9 $i
          done
returns:-
But executing the modified “kill loop” code does not kill task 19716.
Anyone here able to tell me why?
I have changed the code in any number of ways to select just this type of vlc task, using grep "9981*, grep “stream”… Only grep “vlc” seems to work.
I thought I knew how this code worked, very mysterious!:confused::confused:
Have you checked that actually returns the PID for vlc?
ps aux|grep  "vlc -I dummy --volume 120 http://name:password@localhost:9981/stream/channelid" | grep -v grep | awk '{print $1}'
