Socat for passing AT commands
Hi,
I have a PC, to which a development board is connected via USB. To the board, a DUT is connected via USB again.
So, PC ------USB1--------> DevBoard -----(USB2)------> DUT
USB1 is /dev/ttyUSB0 (in the PC)
USB2 is /dev/ttyUSB2 (in the board)
If I need to pass AT commands from PC to DUT, can I use socat? If yes, please share some inputs on how the command would look like.
Thanks and regards,
Sai.
Hi Siam - and welcome to the Forum.
First thing: Please put your posts on appropriate Board - we had to move it here. Indeed, if you had read the New Members’ Guide (where you posted) you would know what to do.
I have no experience of socat but a web search seems to indicate that you can’t get all the way from a PC command through your Development Board to your DUT.
But you might be able to get socat to create a file on your DB that you could read via s/w you write for the DB. Just a thought.
There are tutorials on the web that might help you.
