[SOLVED] After 'fixing' a previous problem, I now have another problem.
The problem I previously had is HERE
I believe the new problem is related as I now no longer have VLC installed and when I tried to install it through Muon Package Manager, I get this;
The “vlc” package could not be marked for installation or upgrade:
Depends: vlc ,but is not installable
Recommends: vlc ,but is not installable
Yes, the warnings appear twice for some reason.
Run:
sudo apt-get clean
now what’s the output from:
sudo apt-get install vlc
Hi Mark, sorry for not getting back to you sooner, me & Mrs pooky have had the flu since Christmas,we’ve almost got over it and now she’s ill in hospital.
I’ll get back to you as soon as I can.
No worries … wish the missus all the best and a speedy recovery from me.
Throw all the insults you like at me but I call it the chemtrail flu. My immediate family for three months now have had bronchitis like chest infections with my heavily pregnant daughter now in intensive care. I’ve never seen anything like this and the doctors at the surgery and those at the hospital haven’t either and it’s right acros
s the U.K.
I tried the suggestion above and was given this;
vlc : Depends: vlc-nox (= 2.1.6-0ubuntu14.04.2) but it is not going to be installed
Depends: libvlccore7 (>= 2.1.0) but it is not going to be installed
Recommends: vlc-plugin-notify (= 2.1.6-0ubuntu14.04.2) but it is not going to be installed
Recommends: vlc-plugin-pulse (= 2.1.6-0ubuntu14.04.2) but it is not going to be installed
Hi pooky2483,
Try
sudo apt-get -f install
that should fix any broken packages messages you are getting
Regards Zeb…
Nope… I still get the error I posted above!
What happens if you run:
sudo apt-get install --reinstall vlc-nox libvlccore7 vlc-plugin-notify vlc-plugin-pulse vlc
I entered
And got;
Reading package lists… Done
Building dependency tree
libvlccore7 : Depends: vlc-data (= 2.1.6-0ubuntu14.04.2) but 2.2.4-3ubuntu2~ubuntu14.04.1york1 is to be installed
I have the feeling this is going to be PPA related again … try:
sudo apt-get install --reinstall vlc-nox libvlccore7 vlc-plugin-notify vlc-plugin-pulse vlc vlc-data
I finally got round to looking at VLC on my desktop again and looked for anything installed which was VLC related and found libvlccore8 so I decided to go for it and purge it.
I then selected to install VLC from Muon Update Manager and IT WORKED!
I now have VLC installed.
