When you get to Demuxers expand the category (in the left hand pane) and you should find AVI in the drop-down list
Is there a way to compress it without doing harm or are AVI files always huge?
They are if you do not use the transcoding option.
You could try in VLC:
Media->Convert / Save->Capture Device:
Set it up as previously
Click Convert / Save
Add destination file
->Settings->Profile
If required (or just select from pre-built):
->Create new profile (adjust to suit)
Name = Video - AVI
Encapsulation = AVI
->Video codec
Video (tick)
Codec = MPEG-4
Bitrate = 8000 kb/s
->Audio codec
-Audio (tick)
-Keep original audio track (tick)
-Save
Select profile Video - AVI
Press Start button to begin.
I personally prefer to capture without transcoding (storage space permitting) as my machine is not quite up to transcoding on the fly.
I would then use another transcoding program to reduce the file size.
[/quote]
I was hoping someone would get OpenShot 1.43 compiled for Puppy Linux LH64-602b but they want to wait for v2.0 (due in December) since it’s a major rewrite. (Compiling an app like that is way over my head.)
I have previously tried Avidemux without good results.
What Linux-friendly video editor would you use post-conversion (via the steps you have been leading me through with VLC) to reduce the file size?
Perhaps it’s already in the repository LH64 uses …
Change the -qscale:v 6 to lower value to get higher bit rate (file size) or to higher value to get lower bit rate (file size)
A change of 6 will double or halve the resulting bit rate.
@HandyGeek
If you are concerned with the audio then you could change it to say -qscale:a 2
Audio does not add much to the file size, so you could up the bitrate by reducing the -qscale:a parameter.
Did you know that if you go to the first post you can edit the title to add SOLVED as instructed here:
