(Solved). flash problem in Ubuntu 14.04
Hello folks,
I had a problem a while back reinstalling Flash in Firefox in Ubuntu 14.04.
Mark suggested the following, and it worked.
sudo apt-get install flashplugin-installer
I’m now having a similar problem in a liveusb of Ubuntu 14.04, but the solution isn’t working. What I get is…
ubuntu@ubuntu:~$ sudo apt-get install flashplugin-installer
Reading package lists… Done
Building dependency tree
E: Unable to locate package flashplugin-installer
Any help appreciated. Thanks.
You probably need to enable the multiverse source first
Applications->System Tools->Preferences->Software & Updates.
Select Ubuntu Software tab and select the entry which (multiverse)
Bingo!
Thanks Sezo - worked perfectly.
Damn, I’ve got a lot to learn about Linux…
Glad it worked for you.
