[SOLVED]Kodak Hero 5.1 on LMDE
I know it’s supported under the c2esp driver (of a fashion), and under the Add Printers page, the Hero 5.1 was listed. It’s connected wirelessly, and the Add Printers dialog seemed happy to find and add it to the system. Printing a test page though, produced absolutely nothing from either the PC or the printer. Is there any kind of log where it would have written errors to? Or can I enable some kind of verbose debug log for printing temporarily? Also, I guess I’m out of luck getting the scanner to work?
This is an LMDE x86 MATE install, fully updated.
  • This is just a stub posting - I can’t provide any more info until the weekend probably, as I won’t have access to the machine. A list of stuff to try would be nice though :slight_smile:
You could check out CUPS error log for debugging and troubleshooting purposes. See here
Thanks SeZo, I’ve also found this one DebuggingPrintingProblems - Ubuntu Wiki which looks quite good (hopefully Ubuntu & Debian don’t differ too much here)
In “Add Printer” did you see if there were any drivers listed under “Eastman Kodak” rather than just “Kodak” ?
Got a result! When I powered the machine up today, it didn’t work (couldn’t connect to printer). So I deleted it and added in the Eastman Kodak (via a default connection), and it printed a test page! Text & images look perfect! :smiley:
Any hope on the scanner? I know less about scanners then I do about printers, and that’s saying something :-[
You might need to install the latest sane-backends from git.
instructions here (for Debian/Ubuntu based distros):
https://help.ubuntu.com/community/CompileSaneFromSource
Well, the compilation took a while - only afterwards did I see on the Sourceforge page for the driver did I see that you can specify in the ./configure action which backends you want!
Anyway, it looks ok, and after specifying a fixed IP rather than autodiscover, the scanner is listed under “scanimage -L”. What now? :stuck_out_tongue:
Scratch that, found there is application under MATE called “Simple Scan”, and it’s working out of the box :smiley:
Cool :slight_smile: … I prefer xsane, but simple-scan works too.
