[SOLVED] Problem with Audacity's config
I tried changing the location where Audacity saves recorded files and now I am getting this error!
I don’t know what to do to be able to get into the preferences and fix the problem as when I click on ‘OK’, Audacity just closes.
[URL=ImageShack - Audacity_Temp_Files.jpg]
ImageShack - Best place for all of your image hosting and image sharing needs
Fixed it.
If anyone else has same problem…
Ubuntu
sudo nautilus ~/.audacity-data
Or
Kubuntu
gksudo dolphin ~/.audacity-data
And just delete or rename the file so that you know what it is.
