SOLVED XSane startup
Hi Folks,
I am back with another problem.
When I try to use XSane to scan it comes up with the error message ;
Error during CMS conversion:
Could not open scanner ICM profile:
Where do I find the ICM profile ?
take care
Don W
I take it Xsane still starts/works ?
If so (and you don’t use colour profiling) … have you tried unchecking Preferences > Enable colour management
If you do use colour profiling, see here:
http://www.xsane.org/doc/sane-xsane-setup-color-management-doc.html
and maybe:
Thanks Mark,
I unchecked Preferences>Enable colour management and it now works.
take care
Don w
