Splash screen missing
Hi all
Using Ubuntu Gnome 16.04.2.
My spalsh screen has gone, helllppp!!!
Do you know your monitors native resolution (or the resolution you’re using now) ?
do you know which graphics driver you’re using ?
Please post the output from:
xrandr
lshw -C display
Hello Mark
Sorry for delay. Is there a way to setup email alerts when post have been replied to?
so my output:
Screen 0: minimum 8 x 8, current 1366 x 768, maximum 32767 x 32767
LVDS1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1366x768 60.04*+
1360x768 59.80 59.96
1280x720 60.00
1024x768 60.00
1024x576 60.00
960x540 60.00
800x600 60.32 56.25
864x486 60.00
640x480 59.94
720x405 60.00
680x384 60.00
640x360 60.00
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
VGA1 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
…and
*-display
product: 2nd Generation Core Processor Family Integrated Graphics Controller
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:27 memory:f7000000-f73fffff memory:e0000000-efffffff ioport:f000(size=64)
Yeah there’s a “NOTIFY” button at the top of every topic page … or you can change your notifications settings in the left hand column in your forum profile … or by following this link:
http://linuxforums.org.uk/index.php?action=profile;area=notification;u=22215
What’s the output from:
update-alternatives --query default.plymouth
Link: /usr/share/plymouth/themes/default.plymouth
Slaves:
default.plymouth.grub /usr/share/plymouth/themes/default.grub
Status: auto
Best: /usr/share/plymouth/themes/ubuntu-gnome-logo/ubuntu-gnome-logo.plymouth
Value: /usr/share/plymouth/themes/ubuntu-gnome-logo/ubuntu-gnome-logo.plymouth
Alternative: /usr/share/plymouth/themes/ubuntu-gnome-logo/ubuntu-gnome-logo.plymouth
Priority: 150
Slaves:
default.plymouth.grub /usr/share/plymouth/themes/ubuntu-gnome-logo/ubuntu-gnome-logo.grub
See if running:
sudo update-initramfs -u
then rebooting makes any difference ?
No, unfortunately no difference. :frowning:
