Toshiba Equium stuck in "BOOTMGR is missing"
I want to put Linux on this laptop which I bought sold as seen and totally untested.
It had Windows Vista on it.
The problem is that none of the “F” buttons actually work so I cannot get into BIOS.
Booting up seems to fail entirely and I do not seem to be able to do anything about it.
The way to get into the BIOS is usually to tap the “Delete” key while rebooting the machine, but have a look at How to boot your Toshiba PC from CD-ROM, LAN, or diskette for Toshiba machines.
That it fails to boot into Vista is not necessarily a problem as Vista is probably u/s.
I suggest that you obtain a Linux Live Disc and boot from that as the disc is usually the first boot medium to be searched. If it doesn’t, then please post the error messages.
