Touchpad left button not working
Okay have worked out how to do a screen shot…I think!
Apologies for the sunny background! :wink:
It might be worth looking in the logs:
gedit /var/log/Xorg.0.log
You should be able to copy text by:
Click (tap) the Touchpad at the end of the text then press and hold Shift key and use the left arrow keys to traverse /highlight (backwards) the desired text.
Next do Ctrl+c to copy and Ctrl+v to paste
Thanks SeZo :slight_smile:
[ 19.277]
X.Org X Server 1.11.3
Release Date: 2011-12-16
[ 19.277] X Protocol Version 11, Revision 0
[ 19.277] Build Operating System: Linux 2.6.24-29-server i686 Ubuntu
[ 19.277] Current Operating System: Linux VGN-NS30E-S 3.2.0-23-generic #36-Ubuntu SMP Tue Apr 10 20:41:14 UTC 2012 i686
[ 19.277] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-23-generic root=UUID=ee6bf75d-fb15-4b29-8f12-1e85050f7904 ro quiet splash vt.handoff=7
[ 19.277] Build Date: 04 April 2012 11:58:38PM
[ 19.277] xorg-server 2:1.11.4-0ubuntu10 (For technical support please see http://www.ubuntu.com/support)
[ 19.277] Current version of pixman: 0.24.4
[ 19.277] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 19.277] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 19.277] (==) Log file: “/var/log/Xorg.0.log”, Time: Thu Apr 4 16:56:10 2013
[ 19.288] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 19.288] (==) No Layout section. Using the first Screen section.
[ 19.288] (==) No screen section available. Using defaults.
[ 19.288] (
) |–>Screen “Default Screen Section” (0)
[ 19.288] (**) | |–>Monitor “”
[ 19.289] (==) No monitor specified for screen “Default Screen Section”.
Using a default monitor configuration.
[ 19.289] (==) Automatically adding devices
[ 19.289] (==) Automatically enabling devices
[ 19.289] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 19.289] Entry deleted from font path.
[ 19.289] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 19.289] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 19.289] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 19.289] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 19.289] (WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
[ 19.289] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 19.289] (==) ModulePath set to “/usr/lib/i386-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules”
[ 19.289] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 19.289] (II) Loader magic: 0x59d5a0
[ 19.289] (II) Module ABI versions:
[ 19.289] X.Org ANSI C Emulation: 0.4
[ 19.289] X.Org Video Driver: 11.0
[ 19.289] X.Org XInput driver : 16.0
[ 19.289] X.Org Server Extension : 6.0
[ 19.290] (–) PCI:*(0:0:2:0) 8086:2a42:104d:9045 rev 7, Mem @ 0xd0000000/4194304, 0xc0000000/268435456, I/O @ 0x0000e140/8
[ 19.290] (–) PCI: (0:0:2:1) 8086:2a43:104d:9045 rev 7, Mem @ 0xd0400000/1048576
[ 19.290] (II) Open ACPI successful (/var/run/acpid.socket)
[ 19.291] (II) LoadModule: “extmod”
[ 19.367] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 19.368] (II) Module extmod: vendor=“X.Org Foundation”
[ 19.368] compiled for 1.11.3, module version = 1.0.0
[ 19.368] Module class: X.Org Server Extension
[ 19.368] ABI class: X.Org Server Extension, version 6.0
[ 19.368] (II) Loading extension MIT-SCREEN-SAVER
[ 19.368] (II) Loading extension XFree86-VidModeExtension
[ 19.368] (II) Loading extension XFree86-DGA
[ 19.368] (II) Loading extension DPMS
[ 19.368] (II) Loading extension XVideo
[ 19.368] (II) Loading extension XVideo-MotionCompensation
[ 19.368] (II) Loading extension X-Resource
[ 19.368] (II) LoadModule: “dbe”
[ 19.368] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 19.368] (II) Module dbe: vendor=“X.Org Foundation”
[ 19.368] (II) Loading extension DOUBLE-BUFFER
[ 19.368] (II) LoadModule: “glx”
[ 19.368] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 19.369] (II) Module glx: vendor=“X.Org Foundation”
[ 19.369] compiled for 1.11.3, module version = 1.0.0
[ 19.369] ABI class: X.Org Server Extension, version 6.0
[ 19.369] (==) AIGLX enabled
[ 19.369] (II) Loading extension GLX
[ 19.369] (II) LoadModule: “record”
[ 19.369] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 19.369] (II) Module record: vendor=“X.Org Foundation”
[ 19.369] compiled for 1.11.3, module version = 1.13.0
[ 19.369] Module class: X.Org Server Extension
[ 19.369] (II) Loading extension RECORD
[ 19.369] (II) LoadModule: “dri”
[ 19.369] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 19.369] (II) Module dri: vendor=“X.Org Foundation”
[ 19.370] compiled for 1.11.3, module version = 1.0.0
[ 19.370] ABI class: X.Org Server Extension, version 6.0
[ 19.370] (II) Loading extension XFree86-DRI
[ 19.370] (II) LoadModule: “dri2”
[ 19.370] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 19.370] (II) Module dri2: vendor=“X.Org Foundation”
[ 19.370] compiled for 1.11.3, module version = 1.2.0
[ 19.370] (II) Loading extension DRI2
[ 19.370] (==) Matched intel as autoconfigured driver 0
[ 19.370] (==) Matched vesa as autoconfigured driver 1
[ 19.370] (==) Matched fbdev as autoconfigured driver 2
[ 19.370] (==) Assigned the driver to the xf86ConfigLayout
[ 19.370] (II) LoadModule: “intel”
[ 19.370] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 19.371] (II) Module intel: vendor=“X.Org Foundation”
[ 19.371] compiled for 1.11.3, module version = 2.17.0
[ 19.371] Module class: X.Org Video Driver
[ 19.371] ABI class: X.Org Video Driver, version 11.0
[ 19.371] (II) LoadModule: “vesa”
[ 19.371] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 19.371] (II) Module vesa: vendor=“X.Org Foundation”
[ 19.371] compiled for 1.11.3, module version = 2.3.0
[ 19.371] (II) LoadModule: “fbdev”
[ 19.372] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 19.372] (II) Module fbdev: vendor=“X.Org Foundation”
[ 19.372] compiled for 1.11.3, module version = 0.4.2
[ 19.372] ABI class: X.Org Video Driver, version 11.0
[ 19.372] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server
[ 19.372] (II) VESA: driver for VESA chipsets: vesa
[ 19.372] (II) FBDEV: driver for framebuffer: fbdev
[ 19.372] (++) using VT number 8
[ 19.379] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 19.379] (WW) Falling back to old probe method for vesa
[ 19.379] (WW) Falling back to old probe method for fbdev
[ 19.379] (II) Loading sub module “fbdevhw”
[ 19.379] (II) LoadModule: “fbdevhw”
[ 19.379] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 19.380] (II) Module fbdevhw: vendor=“X.Org Foundation”
[ 19.380] compiled for 1.11.3, module version = 0.0.2
[ 19.380] ABI class: X.Org Video Driver, version 11.0
[ 19.380] drmOpenDevice: node name is /dev/dri/card0
[ 19.380] drmOpenDevice: open result is 9, (OK)
[ 19.380] drmOpenByBusid: Searching for BusID pci:0000:00:02.0
[ 19.380] drmOpenByBusid: drmOpenMinor returns 9
[ 19.380] drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
[ 19.380] (II) intel(0): Creating default Display subsection in Screen section
“Default Screen Section” for depth/fbbpp 24/32
[ 19.380] (==) intel(0): Depth 24, (–) framebuffer bpp 32
[ 19.380] (==) intel(0): RGB weight 888
[ 19.380] (==) intel(0): Default visual is TrueColor
[ 19.380] (II) intel(0): Integrated Graphics Chipset: Intel(R) GM45
[ 19.380] (–) intel(0): Chipset: “GM45”
[ 19.380] () intel(0): Relaxed fencing enabled
[ 19.380] (
) intel(0): Wait on SwapBuffers? enabled
[ 19.380] () intel(0): Triple buffering? enabled
[ 19.380] (
) intel(0): Framebuffer tiled
[ 19.380] () intel(0): Pixmaps tiled
[ 19.380] (
) intel(0): 3D buffers tiled
[ 19.380] () intel(0): SwapBuffers wait enabled
[ 19.380] (==) intel(0): video overlay key set to 0x101fe
[ 19.380] (II) intel(0): Output LVDS1 has no monitor section
[ 19.381] (II) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 19.396] (II) intel(0): Output VGA1 has no monitor section
[ 19.448] (II) intel(0): Output DP1 has no monitor section
[ 19.448] (II) intel(0): EDID for output LVDS1
[ 19.448] (II) intel(0): Not using default mode “320x240” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “400x300” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “512x384” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “640x480” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “640x512” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “800x600” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “896x672” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “928x696” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “960x720” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “576x432” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “680x384” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “700x525” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “720x450” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “800x512” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “840x525” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “960x540” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “960x600” (doublescan mode not supported)
[ 19.448] (II) intel(0): Not using default mode “1024x768” (doublescan mode not supported)
[ 19.448] (II) intel(0): Printing probed modes for output LVDS1
[ 19.448] (II) intel(0): Modeline "1280x800"x59.9 70.71 1280 1296 1344 1430 800 804 807 825 -hsync -vsync (49.4 kHz)
[ 19.448] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
[ 19.448] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz)
[ 19.448] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz)
[ 19.448] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz)
[ 19.464] (II) intel(0): EDID for output VGA1
[ 19.516] (II) intel(0): EDID for output DP1
[ 19.516] (II) intel(0): Output LVDS1 connected
[ 19.516] (II) intel(0): Output VGA1 disconnected
[ 19.516] (II) intel(0): Output DP1 disconnected
[ 19.516] (II) intel(0): Using exact sizes for initial modes
[ 19.516] (II) intel(0): Output LVDS1 using initial mode 1280x800
[ 19.516] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 19.516] (II) intel(0): Kernel page flipping support detected, enabling
[ 19.516] (==) intel(0): DPI set to (96, 96)
[ 19.516] (II) Loading sub module “fb”
[ 19.516] (II) LoadModule: “fb”
[ 19.516] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 19.516] (II) Module fb: vendor=“X.Org Foundation”
[ 19.516] compiled for 1.11.3, module version = 1.0.0
[ 19.516] ABI class: X.Org ANSI C Emulation, version 0.4
[ 19.516] (II) Loading sub module “dri2”
[ 19.516] (II) LoadModule: “dri2”
[ 19.517] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 19.517] (II) Module dri2: vendor=“X.Org Foundation”
[ 19.517] compiled for 1.11.3, module version = 1.2.0
[ 19.517] ABI class: X.Org Server Extension, version 6.0
[ 19.517] (II) UnloadModule: “vesa”
[ 19.517] (II) Unloading vesa
[ 19.517] (II) UnloadModule: “fbdev”
[ 19.517] (II) Unloading fbdev
[ 19.517] (II) UnloadModule: “fbdevhw”
[ 19.517] (II) Unloading fbdevhw
[ 19.517] (==) Depth 24 pixmap format is 32 bpp
[ 19.517] (II) intel(0): [DRI2] Setup complete
[ 19.517] (II) intel(0): [DRI2] DRI driver: i965
[ 19.517] (II) intel(0): Allocated new frame buffer 1280x800 stride 5120, tiled
[ 19.529] (II) UXA(0): Driver registered support for the following operations:
[ 19.529] (II) solid
[ 19.529] (II) copy
[ 19.529] (II) composite (RENDER acceleration)
[ 19.529] (II) put_image
[ 19.529] (II) get_image
[ 19.530] (==) intel(0): Backing store disabled
[ 19.530] (==) intel(0): Silken mouse enabled
[ 19.530] (II) intel(0): Initializing HW Cursor
[ 19.560] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 19.641] (==) intel(0): DPMS enabled
[ 19.641] (==) intel(0): Intel XvMC decoder enabled
[ 19.641] (II) intel(0): Set up textured video
[ 19.641] (II) intel(0): [XvMC] xvmc_vld driver initialized.
[ 19.641] (II) intel(0): direct rendering: DRI2 Enabled
[ 19.641] (==) intel(0): hotplug detection: “enabled”
[ 19.641] (–) RandR disabled
[ 19.641] (II) Initializing built-in extension Generic Event Extension
[ 19.641] (II) Initializing built-in extension SHAPE
[ 19.641] (II) Initializing built-in extension MIT-SHM
[ 19.641] (II) Initializing built-in extension XInputExtension
[ 19.641] (II) Initializing built-in extension XTEST
[ 19.641] (II) Initializing built-in extension BIG-REQUESTS
[ 19.641] (II) Initializing built-in extension SYNC
[ 19.641] (II) Initializing built-in extension XKEYBOARD
[ 19.641] (II) Initializing built-in extension XC-MISC
[ 19.641] (II) Initializing built-in extension SECURITY
[ 19.641] (II) Initializing built-in extension XINERAMA
[ 19.641] (II) Initializing built-in extension XFIXES
[ 19.641] (II) Initializing built-in extension RENDER
[ 19.641] (II) Initializing built-in extension RANDR
[ 19.641] (II) Initializing built-in extension COMPOSITE
[ 19.641] (II) Initializing built-in extension DAMAGE
[ 19.655] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 19.655] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 19.655] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 19.655] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 19.655] (II) AIGLX: Loaded and initialized i965
[ 19.655] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 19.656] (II) intel(0): Setting screen physical size to 338 x 211
[ 19.665] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 19.669] (II) config/udev: Adding input device Video Bus (/dev/input/event6)
[ 19.669] (
) Video Bus: Applying InputClass “evdev keyboard catchall”
[ 19.669] (II) LoadModule: “evdev”
[ 19.670] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 19.670] (II) Module evdev: vendor=“X.Org Foundation”
[ 19.670] compiled for 1.11.3, module version = 2.7.0
[ 19.670] Module class: X.Org XInput Driver
[ 19.670] ABI class: X.Org XInput driver, version 16.0
[ 19.670] (II) Using input driver ‘evdev’ for ‘Video Bus’
[ 19.670] () Video Bus: always reports core events
[ 19.670] (
) evdev: Video Bus: Device: “/dev/input/event6”
[ 19.670] (–) evdev: Video Bus: Vendor 0 Product 0x6
[ 19.670] (–) evdev: Video Bus: Found keys
[ 19.670] (II) evdev: Video Bus: Configuring as keyboard
[ 19.670] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/LNXVIDEO:00/input/input6/event6”
[ 19.670] (II) XINPUT: Adding extended input device “Video Bus” (type: KEYBOARD, id 6)
[ 19.670] (
) Option “xkb_rules” “evdev”
[ 19.670] () Option “xkb_model” “pc105”
[ 19.670] (
) Option “xkb_layout” “gb”
[ 19.673] (II) XKB: reuse xkmfile /var/lib/xkb/server-2B4266AA55228AE7D9557A18F1965DBA19850816.xkm
[ 19.674] (II) config/udev: Adding input device Sony Vaio Keys (/dev/input/event3)
[ 19.674] () Sony Vaio Keys: Applying InputClass “evdev keyboard catchall”
[ 19.674] (II) Using input driver ‘evdev’ for ‘Sony Vaio Keys’
[ 19.674] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 19.674] (
) Sony Vaio Keys: always reports core events
[ 19.674] () evdev: Sony Vaio Keys: Device: “/dev/input/event3”
[ 19.674] (–) evdev: Sony Vaio Keys: Vendor 0x104d Product 0
[ 19.674] (–) evdev: Sony Vaio Keys: Found keys
[ 19.674] (II) evdev: Sony Vaio Keys: Configuring as keyboard
[ 19.674] (
) Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0A08:00/device:01/SNY5001:00/input/input3/event3”
[ 19.674] (II) XINPUT: Adding extended input device “Sony Vaio Keys” (type: KEYBOARD, id 7)
[ 19.674] () Option “xkb_rules” “evdev”
[ 19.674] (
[ 19.674] () Option “xkb_layout” “gb”
[ 19.675] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 19.675] (
) Power Button: Applying InputClass “evdev keyboard catchall”
[ 19.675] (II) Using input driver ‘evdev’ for ‘Power Button’
[ 19.675] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 19.675] () Power Button: always reports core events
[ 19.675] (
) evdev: Power Button: Device: “/dev/input/event1”
[ 19.675] (–) evdev: Power Button: Vendor 0 Product 0x1
[ 19.675] (–) evdev: Power Button: Found keys
[ 19.675] (II) evdev: Power Button: Configuring as keyboard
[ 19.675] () Option “config_info” “udev:/sys/devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input1/event1”
[ 19.675] (II) XINPUT: Adding extended input device “Power Button” (type: KEYBOARD, id 8)
[ 19.675] (
[ 19.675] () Option “xkb_model” “pc105”
[ 19.675] (
[ 19.676] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 19.676] (II) No input driver specified, ignoring this device.
[ 19.676] (II) This device may have been added with another device file.
[ 19.676] (II) config/udev: Adding input device UVC Camera (05ca:18b3) (/dev/input/event5)
[ 19.676] () UVC Camera (05ca:18b3): Applying InputClass “evdev keyboard catchall”
[ 19.676] (II) Using input driver ‘evdev’ for ‘UVC Camera (05ca:18b3)’
[ 19.676] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 19.676] (
) UVC Camera (05ca:18b3): always reports core events
[ 19.676] () evdev: UVC Camera (05ca:18b3): Device: “/dev/input/event5”
[ 19.676] (–) evdev: UVC Camera (05ca:18b3): Vendor 0x5ca Product 0x18b3
[ 19.676] (–) evdev: UVC Camera (05ca:18b3): Found keys
[ 19.676] (II) evdev: UVC Camera (05ca:18b3): Configuring as keyboard
[ 19.676] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1a.7/usb1/1-2/1-2:1.0/input/input5/event5”
[ 19.677] (II) XINPUT: Adding extended input device “UVC Camera (05ca:18b3)” (type: KEYBOARD, id 9)
[ 19.677] () Option “xkb_rules” “evdev”
[ 19.677] (
[ 19.677] () Option “xkb_layout” “gb”
[ 19.677] (II) config/udev: Adding input device HDA Intel Mic (/dev/input/event7)
[ 19.677] (II) No input driver specified, ignoring this device.
[ 19.677] (II) This device may have been added with another device file.
[ 19.678] (II) config/udev: Adding input device HDA Intel Headphone (/dev/input/event8)
[ 19.678] (II) No input driver specified, ignoring this device.
[ 19.678] (II) This device may have been added with another device file.
[ 19.678] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event2)
[ 19.678] (
) AT Translated Set 2 keyboard: Applying InputClass “evdev keyboard catchall”
[ 19.678] (II) Using input driver ‘evdev’ for ‘AT Translated Set 2 keyboard’
[ 19.678] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 19.678] () AT Translated Set 2 keyboard: always reports core events
[ 19.678] (
) evdev: AT Translated Set 2 keyboard: Device: “/dev/input/event2”
[ 19.678] (–) evdev: AT Translated Set 2 keyboard: Vendor 0x1 Product 0x1
[ 19.678] (–) evdev: AT Translated Set 2 keyboard: Found keys
[ 19.678] (II) evdev: AT Translated Set 2 keyboard: Configuring as keyboard
[ 19.678] () Option “config_info” “udev:/sys/devices/platform/i8042/serio0/input/input2/event2”
[ 19.678] (II) XINPUT: Adding extended input device “AT Translated Set 2 keyboard” (type: KEYBOARD, id 10)
[ 19.678] (
[ 19.678] () Option “xkb_model” “pc105”
[ 19.678] (
[ 19.679] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event9)
[ 19.679] () SynPS/2 Synaptics TouchPad: Applying InputClass “evdev touchpad catchall”
[ 19.679] (
) SynPS/2 Synaptics TouchPad: Applying InputClass “touchpad catchall”
[ 19.679] (II) LoadModule: “synaptics”
[ 19.679] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 19.679] (II) Module synaptics: vendor=“X.Org Foundation”
[ 19.679] compiled for 1.11.3, module version = 1.5.99
[ 19.680] Module class: X.Org XInput Driver
[ 19.680] ABI class: X.Org XInput driver, version 16.0
[ 19.680] (II) Using input driver ‘synaptics’ for ‘SynPS/2 Synaptics TouchPad’
[ 19.680] (II) Loading /usr/lib/xorg/modules/input/synaptics_drv.so
[ 19.680] () SynPS/2 Synaptics TouchPad: always reports core events
[ 19.680] (
) Option “Device” “/dev/input/event9”
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: x-axis range 1472 - 5696
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: y-axis range 1408 - 5232
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: pressure range 0 - 255
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: finger width range 0 - 15
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: buttons: left right
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: Vendor 0x2 Product 0x7
[ 19.688] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 19.688] () SynPS/2 Synaptics TouchPad: always reports core events
[ 19.703] (
) Option “config_info” “udev:/sys/devices/platform/i8042/serio1/input/input9/event9”
[ 19.703] (II) XINPUT: Adding extended input device “SynPS/2 Synaptics TouchPad” (type: TOUCHPAD, id 11)
[ 19.703] () synaptics: SynPS/2 Synaptics TouchPad: (accel) MinSpeed is now constant deceleration 2.5
[ 19.703] (
) synaptics: SynPS/2 Synaptics TouchPad: MaxSpeed is now 1.75
[ 19.703] () synaptics: SynPS/2 Synaptics TouchPad: AccelFactor is now 0.035
[ 19.703] (
) SynPS/2 Synaptics TouchPad: (accel) keeping acceleration scheme 1
[ 19.703] () SynPS/2 Synaptics TouchPad: (accel) acceleration profile 1
[ 19.703] (
) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 19.703] () SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 19.703] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 19.703] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse1)
[ 19.703] (
) SynPS/2 Synaptics TouchPad: Ignoring device from InputClass “touchpad ignore duplicates”
[ 19.706] (II) config/udev: Adding input device Sony Vaio Jogdial (/dev/input/event4)
[ 19.706] (II) No input driver specified, ignoring this device.
[ 19.706] (II) This device may have been added with another device file.
[ 19.706] (II) config/udev: Adding input device Sony Vaio Jogdial (/dev/input/mouse0)
[ 21.716] (II) XKB: reuse xkmfile /var/lib/xkb/server-03AF3717FF3AB439A4BAABA686CCB40771CDF520.xkm
[ 21.769] (II) XKB: reuse xkmfile /var/lib/xkb/server-7996F6726817F73651B9DE0FDA11E35FC4524568.xkm
[ 25.531] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 25.536] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 25.542] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 25.547] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 25.553] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 25.558] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 25.564] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 40.793] (II) XKB: reuse xkmfile /var/lib/xkb/server-E0CEE3138D3C43CB52C449CA640DB68169ADC155.xkm
[ 3619.884] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 3628.718] (II) config/udev: removing device UVC Camera (05ca:18b3)
[ 3628.718] (II) evdev: UVC Camera (05ca:18b3): Close
[ 3628.718] (II) UnloadModule: “evdev”
[ 3628.718] (II) Unloading evdev
[ 3628.735] (II) Open ACPI successful (/var/run/acpid.socket)
[ 3628.735] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 3628.808] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 3629.439] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.448] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.455] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.461] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.467] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.473] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.480] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.486] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.492] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.498] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.505] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.511] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.517] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.524] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.530] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.537] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.543] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.549] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3629.556] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 3673.046] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 7290.225] (II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/mouse2)
[ 7290.225] (II) No input driver specified, ignoring this device.
[ 7290.225] (II) This device may have been added with another device file.
[ 7290.227] (II) config/udev: Adding input device PS/2+USB Mouse (/dev/input/event5)
[ 7290.227] () PS/2+USB Mouse: Applying InputClass “evdev pointer catchall”
[ 7290.227] (II) Using input driver ‘evdev’ for ‘PS/2+USB Mouse’
[ 7290.227] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 7290.227] (
) PS/2+USB Mouse: always reports core events
[ 7290.227] () evdev: PS/2+USB Mouse: Device: “/dev/input/event5”
[ 7290.227] (–) evdev: PS/2+USB Mouse: Vendor 0x1267 Product 0x201
[ 7290.227] (–) evdev: PS/2+USB Mouse: Found 3 mouse buttons
[ 7290.227] (–) evdev: PS/2+USB Mouse: Found scroll wheel(s)
[ 7290.227] (–) evdev: PS/2+USB Mouse: Found relative axes
[ 7290.227] (–) evdev: PS/2+USB Mouse: Found x and y relative axes
[ 7290.227] (II) evdev: PS/2+USB Mouse: Configuring as mouse
[ 7290.227] (II) evdev: PS/2+USB Mouse: Adding scrollwheel support
[ 7290.228] (
) evdev: PS/2+USB Mouse: YAxisMapping: buttons 4 and 5
[ 7290.228] () evdev: PS/2+USB Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 7290.228] (
) Option “config_info” “udev:/sys/devices/pci0000:00/0000:00:1d.1/usb7/7-2/7-2:1.0/input/input10/event5”
[ 7290.228] (II) XINPUT: Adding extended input device “PS/2+USB Mouse” (type: MOUSE, id 9)
[ 7290.228] (II) evdev: PS/2+USB Mouse: initialized for relative axes.
[ 7290.228] () PS/2+USB Mouse: (accel) keeping acceleration scheme 1
[ 7290.228] (
) PS/2+USB Mouse: (accel) acceleration profile 0
[ 7290.228] () PS/2+USB Mouse: (accel) acceleration factor: 2.000
[ 7290.228] (
) PS/2+USB Mouse: (accel) acceleration threshold: 4
[ 7618.752] (II) config/udev: removing device PS/2+USB Mouse
[ 7618.752] (II) evdev: PS/2+USB Mouse: Close
[ 7618.753] (II) UnloadModule: “evdev”
[ 7618.753] (II) Unloading evdev
[ 10508.710] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 10508.733] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
[ 11117.556] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 11198.156] (II) Open ACPI successful (/var/run/acpid.socket)
[ 11198.156] (II) AIGLX: Resuming AIGLX clients after VT switch
[ 11198.233] (–) synaptics: SynPS/2 Synaptics TouchPad: touchpad found
[ 11207.428] (II) XKB: reuse xkmfile /var/lib/xkb/server-4E634B280B0E5C069EA80E39EF9080F0A8FC0600.xkm
I can see nothing wrong in there … it knows there are left and right buttons present.
But if xev iis not giving output I’d say the button is broken.
Test it with a Mint LiveCD … you KNOW it worked originally, so if it doesn’t work with the liveCD, you KNOW it’s broken.
There’s no point in looking for a software fix until you know it’s not a hardware problem :wink:
Will do.
