Unable to get script working when I need it to
I’m trying to get a script to work on boot, but I’m having problems.
I want the script to execute after I have got an internet connection as they will be useless if executed before.
I want the script to do three things;
1 connect to a VPN
2 start onedrive (using dolphin, I can access my MS OneDrive folder(s)
3 start GoogleDrive (same as #2)
Yet, when the script is run, nothing happens.
The script
#!/bin/bash
sleep 30
expressvpn connect ukdo
onedrive-d start
google-drive-ocamlfuse /media/pooky2483/EXT-05-8Tb/Google-Drive/
I would also like to be notified which command is being executed, possibly by way of some kind of on-screen message.
does running those 4 commands work if run manually one after the other in a terminal ?
and does Kubuntu use “konsole” as the terminal ?
Yes
and does Kubuntu use "konsole" as the terminal ?
Yes
Why not add the lines one at a time to your script
so
#!/bin/bash
sleep 30
run the script and see if it connects to expressvpn
if it does, make it read
#!/bin/bash
sleep 30
onedrive-d start
and if that works
#!/bin/bash
sleep 30
onedrive-d start
to get an idea where it’s failing.
do any of those commands require elevated permissions ?
I’ve discovered that expressvpn has a command which I can set so it automatically connects when it gets an internet conenction, so I can drop that one from the script.
I think I’ll have to find out how long it takes for my PC to boot up and obtain a connection, then adjust the ‘sleep’ accordingly.
I’ll have another go when I’ve finished backing up all my files… May be a little while…
