Unstable network connection
On that PC it could be the hardware decryption … which is why I suggested disabling it :slight_smile:
On that PC it could be the hardware decryption .. which is why I suggested disabling it
Well if that’s the case then there’s no harm in trying that now to see if it improves the download speed if it has an adverse effect then all I have to do is reboot ?
pat@Linux2 ~ $ sudo modprobe -r rt2800pci
[sudo] password for pat:
pat@Linux2 ~ $ sudo modprobe rt2800pci nohwcrypt=1
sudo: unable to resolve host Linux2
pat@Linux2 ~ $
so what happens if you now run:
pat@Linux2 ~ $
The first command disconnected the network, the second command re-connected
OK, dunno why you’re getting the sudo error message … but sudo is obviously working
Run these again
and see if the download speeds have improved.
OK I would say there’s no significant change after the changes,
running the speed tests are naturally inconsistent anyway so I ran the test 3 times with and without the changes
before changes 13.12mb/s 6.55mb/s 10.05mb/s average 9.90mb/s
after changes 11.10mb/s 13.05mb/s 10.90mb/s average 11.68mb/s
so although I had a slightly faster average after the change the highest speed was achieved without the change
I’m not really sure if this is even a problem the download speed is naturally higher than I previously reported and the internet is working fine and seems fast enough it’s just that compared to the other PC’s on the same network this PC (Linux2) is showing significantly slower download speeds, I took the same average readings with the other 2 PC’s and the averages are Linux1=43.00mb/s & Linux3=29.84mb/s
Well if it’s currently working, probably best to leave alone for now then :slight_smile:
Well if it's currently working, probably best to leave alone for now then
That sounds like a cunning plan :slight_smile:
Thanks again
Yup, a genuine mastermind, me 8)
