Update red cross
Have update notice but red cross next to it, I can see that it’s for Ubuntu so do this not apply to Mint distro even though based on Ubuntu?
https://i.postimg.cc/nc3CPs7Z/Screenshot_from_2018-09-18_09-24-58.png
Is the a way to filter updates to only the ones relevent for Mint.
Thanks
That’s not what’s happening here, Mint draws the vast majority (98% ish as a guess) of its packages directly from the upstream Ubuntu repos so the vast majority of updates will have "ubuntu’ in their version numbers.
To me it looks like that box is just telling you the upgrade is selected to be installed automatically unless for some reason you don’t want it, then you can remove the X by clicking on it.
Just accept the update (which is the correct version for Ubuntu 18.04 and therefore Mint 19).
Ah ok thanks.
No problem :slight_smile:
