USB with write protected partition resolved
I went to a conference and got a device so logging contacts. Basic a USB stick with 2 partitions 2Gb and a small 160Mb partition that is write protected. Dose anyone know a way to remove the write protection so I can use the whole of the stick.
Thanks in advance…
Easiest way …
Copy everything you want from it to your PC
then use Gparted or Disk Utility to delete all the partitions, then create a single FAT32 partition.
Then copy your stuff back.
That sorted it out thanks for the help.
No problem :slight_smile:
