USING DOS BOX (Resolved)
I have installed DOS Box as I have some old DOS games that we like playing.
I have been using the program in XP for years and understand all about mounting drives.
But I have problems in Linux:
  1. I can not mount the CD/DVD ROM from inside DOS Box.
  2. I can not install the games that are on CD’s (in windows XP you just install the game into the folder you are using as your DOS Box C:\ drive).
Any help would be most welcome or am I having to stay with windows to use DOS Box.
OK, manually mounting a CD is DOSBOX…
  1. Insert you CD
  2. In Ubuntu, go to the /media directory and write down what the directory name of the mounted CD
OK, lets say it was mounted as /media/Ubuntu 11.04 amd64
  1. In DOSBOX, enter:
mount d "/media/Ubuntu 11.04 amd64" -t cdrom
This will mount it as the D:\ drive in DOSBOX
mount e "/media/Ubuntu 11.04 amd64" -t cdrom
(you only have to use quotation marks if there are spaces in the path)
Will mount it as the E:\ drive in DOSBOX
etc.
You can mount an Ubuntu directory as a drive in DOSBOX too.
lets say I wanted to mount my home directory as the F:\ drive in DOSBOX
mount f /home/mark
Hi I am still unable to mount the CDROM
The path is mount d "/media/STARGUNNER -t cdrom
I am told the directory dose not exist
I have no problems mounting the C:/ drive
mount c "/oldgames
you didn’t close the quotation marks…
mount d "/media/STARGUNNER" -t cdrom
Although because the path has no spaces, you don’t NEED the quotation marks, so:
mount d /media/STARGUNNER -t cdrom
should also work.
All working fine now thanks for your help.
I think I am beginning to see how DOSBOX works in Linux.
