Virtual environment creation
I have cause to use xp from time to time for things like the sat nag updates and as I am about to convert my last laptop to Linux (PM4) I have decided to go down the route of installing Virtualbox.
TBH download install and set up was pretty straight forward.
Now for the question, does anyone know a safe DL for an XP iso or maybe a later version?
i would suggest to stick with a known source. Like the original XP install disk. Install it in the virtual environment, then update it.
(once done that keep a backup copy if the image file)
Yeh I would but I’ve never had a disc, it’s always been pre installed.
We have a disc at work but I’m impatient and bored.
OK, in that case you may want to look at this: Convert your Computer into a Virtual Machine and then use that VHD in your Virtualbox.
