So what happens with guvcview ?
and does running it from the terminal give any cues ?
It just doesn’t open I’ve tried un-installing and re-installing
I don’t know, I’m at work at the moment but I’ll try that and report back
Many thanks
Hi again
Here’s the output for opewning guvcview
graeme@Linux1 ~ $ guvcview
guvcview 1.5.3
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib audio/pcm_bluetooth.c:1614:(audioservice_expect) BT_GET_CAPABILITIES failed : Input/output error(5)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
video device: /dev/video0
Unable to find parent usb device.Unable to find parent usb device.Init. BT848A video (Hauppauge (bt848) (location: PCI:0000:02:02.0)
{ pixelformat = 'GREY', description = '8 bpp, gray' }
VIDIOC_ENUM_FRAMESIZES - Error enumerating frame sizes: Inappropriate ioctl for device
Unable to enumerate frame sizes.
{ pixelformat = 'HI24', description = '8 bpp, dithered color' }
{ not supported - request format(875710792) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBO', description = '15 bpp RGB, le' }
{ not supported - request format(1329743698) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBQ', description = '15 bpp RGB, be' }
{ not supported - request format(1363298130) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBP', description = '16 bpp RGB, le' }
{ not supported - request format(1346520914) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGBR', description = '16 bpp RGB, be' }
{ not supported - request format(1380075346) support at http://guvcview.sourceforge.net }
{ pixelformat = 'BGR3', description = '24 bpp RGB, le' }
{ ?GSPCA? : width = 640, height = 480 }
fmtind:2 fsizeind: 1
{ pixelformat = 'BGR4', description = '32 bpp RGB, le' }
{ not supported - request format(877807426) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGB4', description = '32 bpp RGB, be' }
{ not supported - request format(876758866) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YUYV', description = '4:2:2, packed, YUYV' }
{ pixelformat = 'UYVY', description = '4:2:2, packed, UYVY' }
{ pixelformat = '422P', description = '4:2:2, planar, Y-Cb-Cr' }
{ not supported - request format(1345466932) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YU12', description = '4:2:0, planar, Y-Cb-Cr' }
fmtind:6 fsizeind: 1
{ pixelformat = 'YV12', description = '4:2:0, planar, Y-Cr-Cb' }
fmtind:7 fsizeind: 1
{ pixelformat = '411P', description = '4:1:1, planar, Y-Cb-Cr' }
{ not supported - request format(1345401140) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YUV9', description = '4:1:0, planar, Y-Cb-Cr' }
{ not supported - request format(961959257) support at http://guvcview.sourceforge.net }
{ pixelformat = 'YVU9', description = '4:1:0, planar, Y-Cr-Cb' }
{ not supported - request format(961893977) support at http://guvcview.sourceforge.net }
{ pixelformat = 'RGB3', description = 'RGB3' }
fmtind:8 fsizeind: 1
vid:0000
pid:0000
driver:bttv
checking format: 1196444237
Format unavailable: 1196444237.
Init v4L2 failed !!
Init video returned -2
trying minimum setup ...
Segmentation fault (core dumped)
graeme@Linux1 ~ $
I haven’t really had a close look … but it looks like bluetooth might be causing an issue, can you remove the bluetooth device, reboot, and try again.
Also, make sre you’ve tuned in the video with xawtv first.
If that helps … you might also want to try cheese without the bluetooth device connected.
