Ok did as requested but I still can’t tune in to cheese or tvtime, Cheese just gives me a snowy picture and I’v tried scanning the channels in tvtime 3 times and I get nothing I’ve attached a screenshot of Cheese preferences showing it’s loading the correct card if that’s any help
graeme@Linux1 ~ $ dmesg | egrep '(bttv|bt84?|tveeprom)'
[ 13.991344] bttv: driver version 0.9.19 loaded
[ 13.991346] bttv: using 8 buffers with 2080k (520 pages) each for capture
[ 15.431674] bttv: Bt8xx card found (0)
[ 15.431698] bttv: 0: Bt848 (rev 18) at 0000:02:02.0, irq: 19, latency: 64, mmio: 0xfdfff000
[ 15.431725] bttv: 0: using: Hauppauge (bt848) [card=2,insmod option]
[ 15.434243] bttv: 0: Hauppauge/Voodoo msp34xx: reset line init [5]
[ 15.467245] tveeprom 6-0050: Hauppauge model 60114, rev CV , serial# 541867
[ 15.467252] tveeprom 6-0050: tuner model is Temic 4002FH5 (idx 14, type 0)
[ 15.467256] tveeprom 6-0050: TV standards PAL(B/G) (eeprom 0x04)
[ 15.467259] tveeprom 6-0050: audio processor is MSP3410D (idx 5)
[ 15.467262] tveeprom 6-0050: has no radio
[ 15.467265] bttv: 0: Hauppauge eeprom indicates model#60114
[ 15.467267] bttv: 0: tuner type=0
[ 15.576571] msp3400 6-0040: MSP3410D-B4 found @ 0x80 (bt848 #0 [sw])
[ 15.693041] bttv: 0: registered device video0
[ 15.693140] bttv: 0: registered device vbi0
graeme@Linux1 ~ $ xawtv -hwscan
This is xawtv-3.102, running on Linux/i686 (3.5.0-17-generic)
looking for available devices
port 95-110
type : Xvideo, image scaler
name : Intel(R) Textured Video
port 111-111
name : Intel(R) Video Overlay
/dev/video0: OK [ -device /dev/video0 ]
type : libv4l
name : BT848A video (Hauppauge (bt848)
flags: overlay capture tuner
graeme@Linux1 ~ $
Don’t expect the TV card to work … it’s liable to be an “analogue” TV tuner … broadcasting of analogue channels ceased in this country a couple of years ago … it all digital (DVB) now, so unless the card is digital you won’t get any TV channels.
Can still be used to “capture” an analogue input though … such as from a video tape recorder.
Sorry got delayed, daughters 21st :-[ @Mark
We do not expect it to pick up any analogue channels other than the coax input from the betamax.
@Emegra
The Cheese picture would indicate that the tuner needs to be adjusted to match the channel of the betamax output.
Try to set up the right source for v4l in xawtv:
xawtv -device /dev/video0
Tune to the correct channel using tvtimer (that worked before) then
Get current TV frequency
v4l2-ctl --get-freq
Save it for later and re-set it as and when required with:
v4l2-ctl --set-freq=<Tune the card to a TV input frequency>
I can’t get tv time to tune in anymore I dont know why , I tried all the possible channels in all the tv standards (PAL, PAL BG etc) in xawtv (channel hopping) but it’s just not happening, I also tried tuning in the VHS I have and it wont tune in either, the odd thing is I did have video in tvtime and cheese but I’ve obviously done something that’s screwed that up.
Anyway it’s late and I have work in the morning if you guys don’t mind continuing this tomorrow I would appreciate it, on the other hand if you tell me to bugger off you’ve had enough I’ll understand
Thank a million for your efforts so far I really appreciate it
Hmm, according to this post he lost the tuning ability before the introduction of the tuner, but it is worth to try to remove that line
and try again tomorrow. :-\
@ Emegra
No problem, we all got our other distractions, well some of us more than others
We made massive progress but now things are worse than ever
firstly I uncommented line options tuner type=0 then opened up xawtv and both machines tuned in perfect, The betamax tuned in on channel 26 and the VHS tuned in on channel 60 the video image was good on both machines although I had no sound on either, I tried recording in xawtv and I got an error message something like error [init], I then tried tvtime and the VHS tuned in on channel 131 but the Betamax wouldn’t tune in at all, both machines tuned into Cheese but again crashed when I tried to record, Then I went back to xawtv and tuned in the VHS it tuned in ok but I was getting vertical interference lines that I couldn’t get rid of so i decided to reboot, after reboot neither Cheese, tvtime or xawtv will open, they just flash open for a second and disappear, the terminal output when xawtv fails says something about lack of resources (video ram) but I can’t post the exact output as I’m at work right now , but I will do that when I get home.
It seems very erratic the way the card behaves. :-\
Just ncommenting the tuner line (without unloading the module) would have left the tuner module loaded until your next boot.
So when you tested the tuning it was in fact with the loaded tuner module. But after the reboot the modification came into effect.
Is it now loaded?
You still haven't confirmed you've connected your TV/Capture card to your soundcard ?
I did answer that on an earlier post
No I didn't think I had to I thought it would receive video and audio through the RF cable
Have you considered creating a Mint 13 or Ubuntu 12.04 LiveUSB with persistence .. booting to it .. and seeing if cheese works in that ?
No I haven't done that but I can can try to install to usb and run that if you think it will help
What was the problem with cheese in Peppermint ?
Cheese wont open in peppermint I’ve tried uninstalling and re-installing but it just wont open
To be honest I’ve been getting quite a lot of weird behaviour in both my Mint & Peppermint installs, I can’t think of a time when I have been more disillusioned with Linux since I moved to it, I understand the problems are probably more my own doing and my lack of understanding rather than the fault of Linux but I seem to be having a hard time with it lately, I’ve even considered reinstalling both operating systems again from scratch but I don’t want to go though all the setting up again if I can avoid it
Also here is the error output when I try to open xawtv
xinerama 0: 1600x900+0+0
vid-open-auto: using analog TV device /dev/video0
WARNING: No DGA direct video mode for this display.
WARNING: keeping fbuf pitch at: 6400, as no base addr was detected
WARNING: couldn't find framebuffer base address, try manual
configuration ("v4l-conf -a <addr>")
v4l2: WARNING: framebuffer base address mismatch
v4l2: me=(nil) v4l=(nil)
Alsa devices: cap: (null) (/dev/video0), out: default
X Error of failed request: BadAlloc (insufficient resources for operation)
Major opcode of failed request: 149 (XVideo)
Minor opcode of failed request: 19 ()
Serial number of failed request: 483
Current serial number in output stream: 484
graeme@Linux1 ~ $
