Why is Peppermint small in Virtualbox?
Hi,
I have been using Peppermint for sometime in Virtualbox, hosting on Ubuntu. But here is one thing that I don’t like. Why in VirtualBox Peppermint screen is too small. Although I found so many causes and solutions which I could not find working for me. Please tell me why is this so and how to make Peppermint (6) screen larger in VirtualBox.
Thank you!
Fire up the Peppermint 6 Virtual Machine, inside the VM open a terminal and run:
sudo apt-get upgrade
sudo apt-get dist-upgrade
then REBOOT the Peppermint 6 VM
Once rebooted, inside the VM open a terminal and run:
sudo apt-get install virtualbox-guest-dkms-lts-utopic
once that’s installed … REBOOT the VM again.
